Question about GE DBSR453EBWW Electric Dryer
The dryer doesn't seem to be timed anymore. when we turn it on at night it keeps running and when we wake up its still going.. sometimes the clothes don't even dry in that period of time.
  • Diana2008 May 07, 2008
    Very old dryer. Takes at least 2 cycles to dry. Have cleaned lint trap
  • dkalandras Aug 12, 2008
    the dryer works fine all the way to 15 minutes left to dry then it stays there,it won't advance any further just keeps running, but dries fine.Model # is DDE5808MCLWH.
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Posted on Jul 01, 2008
  • 156 Answers
If the element not heating dryer timer will not advance if element good vent clean you probley have a bad thermostate
Posted on Mar 06, 2008
Dryer stay hot
It's very possible your element shorted to ground causing the element to get constant currant from the wall outlet if it was hot without running, if thats the case you need to replace the heating element.
Jan 15, 2014 | Dryers
Hi-Limit Thermostat
Hi Frank Liles..
Here are a few causes and things to check
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork .
This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 17, 2012 | Bosch Nexxt WTMC3321US Electric Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
Heating Element
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
Sep 27, 2012 | Frigidaire Dryers
My dryer runs and heats up but doesn't dry the clothes. i noticed some dampness on dryer door when i open it. the clothes circulate but don't fully dry. i noticed the dryer is heated and light is...
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 30, 2011 | Kenmore 600 7962 Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
GE DBSR453EBWW Electric Dryer Logo
103 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
