You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is
displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
To
reset the SWS (SyncThru Web Service) password:
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
