Question about HP Photosmart 2610 All-In-One InkJet Printer
Error Message I have the photosmart 2610 all-in-one it worked fine utill 2 days ago I turned it on and the display screen on the printer has an error message 0x886a6b73 on display screen, I can hit the power button all day and it will go back to the same screen...I downloaded 4 updates beforehand...but I never had a problem with those updates before...please help!!
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Posted on Mar 30, 2008
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
http://www.youtube.com/watch?v=RTFOBtdthAc
Good luck
www.inkjet411.com
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
Incorrect cartridge error message when I replaced the cartridges with two new original HP cartridges. HP95 & HP96. The printer will not print. I have turned off and on the printer. I have rebooted...
HpCartridge issue Completethe steps below in the order presented to resolve the problem. It might not benecessary to complete all of the steps. Stepone: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Steptwo: Clean the cartridge contacts Figure1: Lifting the top cover clip_image001.gif
  1. Lift the top cover.
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure2: Unlatching cartridge clip_image002.gif 1- Black cartridge 2- Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure3: Removing cartridge clip_image003.gif
  1. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  2. Lightly moisten the swab and squeeze out excess moisture.
  3. Holding the cartridge by its handle, wipe the copper contacts.
Figure4: Wiping the contacts clip_image004.gif 1- Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Stepthree: Replace the cartridge
Dec 21, 2010 | HP Photosmart 2610 All-In-One InkJet...
My HP Photosmart 2610 won't recognise compatible cartridges, help
You can try buffing the contacts gently but this happens quite often with generic cartriges sometimes they just don't work. Contact the vendor and explain the issue, I reckon you'll find that they're fairly used to this problem and will request a return for a refund.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error message: ink device failure oxc18a0506
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jun 18, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
Hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Feb 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error Message Error 0x886a6b72
I contacted www.hp.com and after a while we decided it is fried.
Lightening had hit my cable box and must have got the printer too.
All it will do is flash even after trying to reset to factory settings.
Thanks for the offer
Jun 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
May 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 error message
Turn off your printer. Look in My Computer for any HP Memory card icons. Right-click on them and disconnect all that you see.
Mar 19, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
