Question about Video Game Consoles & Games
Sony TV problem.
This TV has normal sound. channels are changed by remote control or micro switch. but no picture. the screen looks like a rainbow.(colour patches) CRT plug changed but fault was not corrected.
Fly Back transformer changed . no results.
can you help me to correct this fault.
  • Hapana Mar 07, 2008
    fault was not corrected yet.
    TDA8375A IC was replaced.
    FLY was replaced.
    There is no OSD.No Pictures on the screen.
    Screen looks like a rainbow.
    Screen control adjusted. but no results.
  • 818 Answers
Follow this procedure to troubleshoot a NO SIGNAL error on the TV screen.
  1. Tune the television to a different channel or input.
  2. NOTES:
    • If the television is displaying the error message on only a few channels or inputs, the issue is being generated by the signal source or a connected external component.
    • Televisions with digital tuners require a signal strength of at least 25% before a digital broadcast will be displayed on the screen.
    • It may be necessary to press the TV, ANT, or AUX button on the remote control to change input back to the television tuner.
  3. Attempt to play a different video source, such as a VCR, through the television tuner.
  4. NOTE: If the error message is not visible when viewing this second video source, the issue is isolated to the signal source being received and no further troubleshooting is necessary.
  5. Turn off the television.
  6. Unplug the television from the AC wall outlet for 60 seconds.
  7. Plug the power cord back into the AC wall outlet.
  8. Turn on the television.
  9. Auto Program the television tuner.
  10. Replace the coaxial cable connecting the video component to the television.
Posted on Mar 06, 2008
    Sergeant:
  • 319 Answers
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Fix blue screen av27870
Hi. Switch off (mains switch) the VCR. Then see if you can change channels with your TV remote. Blue screen mostly means that no channel has been programmed. If there is , you should at least have the sound. So, if you have sound, there is an internal problem in the TV. If no sound appears, try to get into setup mode (button Menu)
and programm your channels. I suppose there is signal on your normal areal connection. Check this out with another TV set, or use the tuner from you VRC. I know there are a lot of possibilities, but you can sort this out, step by step. Good luck.
Oct 18, 2014 | JVC Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
How can i get my tv to stop automatically changing to menu screen?
slapshot,
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Nov 14, 2007 | Televison & Video
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
No picture - sound always on
1}Take batts out of remote,in case it is sending from a stuck button. 2)Check all tactil switches 3)Check for liquid spill damage in area of micro and tact switches.
Oct 03, 2007 | Sony KV-27V65 27" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Video Game Consoles & Games Logo
61 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
