Question about Toshiba TDP-MT200 Multimedia Projector
PROJECTOR WILL NOT POWER ON
I HAVE AND BUY A FEW PROJECTORS WHAT ARE THE MOST COMMON CAUSES FOR THE PROJECTOR NOT POWERING UP
  • 682 Answers
1-bad power cable 2-blown fuse 3-defective power supply.4-serious trouble in main board.
Posted on Mar 14, 2008
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
www.projectorreviews.com/articles-guides/lamp-life-and-brightness-2/
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
https://community.spiceworks.com/.../2235-resetting-lamp-hours-on-a-sh...
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
https://www.youtube.com/watch?v=sPGZSJXpxqI
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Plc-xu30 wont power up
Switching of Projector within few seconds ??!!
This problem is common when Projector lamp is not replaced with that of the same band & model but one can fool the projector lamp as it powered with logic switching ...0 V or 5 V set by its company ...
Go through following Web :
http://www.diy-community.de/forumdisplay.php?f=60
http://www.allinbox.com/modding.htm
http://www.dity.nl/forum/lampen/442-...qi-lampen.html
http://recklessphilosophers.com/2008...ad-of-300.aspx
Jun 20, 2012 | Sanyo PLC XU33 Multimedia Projector
Projector is plugged in with power but does not come on. I have checked socket and cord up to projector with multimeter to verify power is up to projector. I pulled the bulb and the filament is still in...
i hear that this is a common fault and that after a few minutes up to a few months they can just suddenly start working again if left plugged in... i have one which has just done the same thing i have taken it apart and checked everything minus the 10000 microchips... my advise would be check the main power board and see if the fuse is still good, the main power board is located in the front right of the projector and is a B!tc# to get at but if this is your problem it will have been worth doing. also be careful if you attempt this as there are alot of small connectors and ribbon cables... it is easily done if you know hat you are doing...
Feb 03, 2011 | Sony VPL CS5 Multimedia Projector
Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
Nov 03, 2008 | NEC VT670 Multimedia Projector
In focus 70+ light flickers
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Aug 06, 2008 | InFocus LP70+ Multimedia Projector
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Mitsubishi XL1XU Projector
Hi there
The most common cause for a Ballast to go faulty is power failures & power spikes and off course lightning.
I normally advise my clients to hook up a UPS to the Projector just to make the power supplied to the Projector more even and smooth.
Ballast problems however occurs more than often on any model of Mitsubishi I have found.
Oct 25, 2007 | Mitsubishi XL1XU Multimedia Projector
Its not the lc-sb20 but the lc-nb3e
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Sep 08, 2007 | Eiki LC-SB20 Projector Multimedia...
Toshiba TDP-MT200 Multimedia Projector Logo
386 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
