Question about Equator SB72 Built-in Dishwasher
Parts needed I need an outlet pipe Part# V24A000Q8 and four brackets Part# V13A000A9 for a Equator model #SB-72/1 dishwasher. Any place where I can find them. Equator is out of stock and it could take 6 weeks to order. I would appreciate any help you can give me! Thanks, Pearl
    Sergeant:
  • 319 Answers
If the manufacturer is out of stock...chances are you will not be able to find them anywhere else. Your best bet would be to go to a metal machinist shop and have some custom made. You can have this done for the pipe as well.
Posted on Mar 06, 2008
  • Equator Master
  • 19,396 Answers
Where are you located?
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
Water vALVE DOES NOT QUITE SHUT OFF. AFTER WASH COMPLETED, water leaks slowly into tub and overflows onto floor. iT IS TYPE 1353-1. wHAT IS PART NUMBER FOR WATER VALVE? pRICE AND WHERE i CAN GET ONE? tHank...
If you can supply the Product number or model number I would be able to help.It would not be a major expense for a new inlet valve.Check if the drain pipe from the dishwasher if going into a pipe outlet in wall that it is not too far down into pipe as this could cause it to syphon back into unit.Also if drain goes to a sink outlet make sure the drain hose is above any other outlets,you could tie hose up into a "U" shape above outlet this will stop waste from sink getting into Dishwasher.
Hope this helps.
Jun 07, 2010 | Dishwashers
Model DU915PKO? dishwasher will not drain
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 22, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Backup of foul smelling water into the dishwasher
Outlet pipe is partially or completely blocked.
Use a dishwasher cleaner in it, but before you even do that, remove outlet pipe from waste pipe - and clear all the gunk out you can.
I suggest a bucket with disinfectant and washing powder to dissolve the grease.
You may need a drain cleaner down the waste pipe too - & flush with hot water and washing powder.
Aug 04, 2009 | GE Profile PDW8400J Built-in Dishwasher
Where can I find parts for Equator WBR72 built in dishwasher
These machines were manufactured by Fagor based in Spain who are not supplying parts for these models to Appliance Desk (Equator's after sales service provider ), however Fagor have their physical presence in America and they should be liable to provide parts for the same. Since they do not want to sell parts to Appliance Desk they should be able to sell parts to the customers directly. In case you would like to purchase parts from them their website address is www.fagoramerica.com
Mar 21, 2009 | Equator SB72 Built-in Dishwasher
32 inch dishwasher...
hello Welcome
I believe Ge makes one to go under a sink!
And that's the only one! that low.
Thank you Huum
please leave a solved rating before you sign off
Dec 07, 2008 | Equator Dishwashers
I need a diagram of an Equator EZ3612CEE door
While you may have removed the door with the hinges from the cabinet the nuts may have fallen down on the unit.
You may want to open the back panel or the bottom panel and try searching for the same, in case you need assistance mounting the bracket back on the cabinet once you have the nuts do let me know.
Nov 24, 2008 | Equator EZ 3612 CEE Front Load...
Soap dispenser
There is a screw cap on the back wall of the dishwasher,unscrew the cap and place your rinse agent in there.I groove on the door is for your dishwasher powder
Apr 09, 2008 | Equator 20 in. CD 400 Compact Dishwasher
Equator EZ 2500C - Need a pump
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website www.appliancedesk.com and also place the order online.
Mar 27, 2008 | Equator EZ 2500C Front Load All-in-One...
Replacement hose connection for Equator 3500
Jan 19, 2008 | Equator 23 in. WB72 / BB72 Built-in...
Equator SB72 Built-in Dishwasher Logo
112 people viewed this question
Top Equator Dishwashers Experts
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
