Question about Radio Communications
Looses frequencies when programmed
We have a Radio Shack Pro 508 Scanner - Electric only. No battery compartments. When you unplug or turn off, you loose all the frequencies programmed in scanner.
  • 28 Answers
If it loses the frequencies immediatly then it sounds like the capacitor that holds the charge for the memory has gone out. If it is sitting for a few days and loses frequencies this is more common. Solution, if you've had it less than a year, take it to your local radioshack, try to find the receipt and have them send it to the repair center for you.
Posted on Mar 15, 2008
HAVE A RADIO SHACK PRO-82 SCANNER, READS L/O IN UPPER RIGHT HAND CORNER HOW DO I UNLOCK?
That means that you have on programs in your scanner...you have program loss hit your program button and you can start programming your frequencies......
Jun 13, 2011 | Radio Shack Pro-82 Scanner
My radio shack pro- 508 scanner has not been plug up in years i want too find a way to get a frequent too listen too the scanner
You can download and print the operating instructions for your scanner, at no cost, here:
http://support.radioshack.com/support_electronics/doc6/6984.htm
If you're looking for frequencies to program into the scanner, visit this site:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jun 11, 2011 | Radio Shack Pro-2018 Scanner
How to reprogram pro 508 scanner codes for the scanner
Hi, my name is John. You can get your frequencies here, www.RadioReference.com ....Steps:..Press MANUAL, Press PGM. Enter the frequency you want, press ENTER/L-OUT ....enjoy...hope this was helpful...
Aug 02, 2010 | Radio Shack Pro-2018 Scanner
Need an antennea that is for pro 508 scanner
The screw-in antenna for your scanner is Radio Shack Catalog number 10538353. You should be able to purchase one, or order one, from your local Radio Shack. Also check eBay - but make sure that it's the correct antenna for you scanner. Not all screw-in antennas have the same thread size. Check prices closely. Considering the age and limited capability of your scanner, you might be better off purchasing a new or used scanner rather than an antenna for the 508.
Bill B
Jun 05, 2010 | Radio Shack Pro-2018 Scanner
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
I am trying to program radio shack pro 97 police scanner need live help
nothing to it. press program, enter frequency, press enter, press program to repeat next frequency.
Thanks,
dodgem250.com
Apr 09, 2010 | Radio Shack Pro-97 Handheld Scanner
Would like to add a frequency to a Radio Shack
Absolutely. Just find either an empty channel or one that you want to delete - and program the new frequency. Doing so will not "mess up" any of the other programming.
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 06, 2010 | Radio Shack Pro-96 Scanner
Radio Shack Pro-508. The lock out key and program
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
Oct 17, 2009 | Radio Shack Pro-2018 Scanner
Looses frequencies programmed
Check your manual to see if there is an internal battery. Many devices use an internal Lithium battery to retain memory. Like any other battery, after time, they will go bad.
The older programmable scanners used to use a 9V battery to retain memory. There was a plate on the back to gain acces to the battery. The newer units may have a long-lasting lithium battery inside.
Please let me know if I can be of futher assistance to you.
- Jim
Mar 06, 2008 | Radio Shack Pro-2018 Scanner
Radio Communications Logo
160 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
