Question about Toshiba TP43H60 43" Television
TP43H60 component input color issue
Does anyone have a list of Toshiba (specifically TP43H60) service menu codes, what they designate, how to get into service mode and how to navigate?
I am trying to adjust only the settings on my component video input. Its very, very dark and very very red. All of the other inputs (s-video, composite) look fine.
  • hifidigital Mar 06, 2008
    I'm sure its not the cables as I tried different sets as well as different components.
    If you could e-mail the manual I'd be very grateful...and if I do kill the set, that might be my cue to buy something new. Something that I could hang on the wall ;)
  • 206 Answers
From our experience letting customer dance around in the service menus usually they end up with a problem way worse or a dead set. It would be best to check the cables first, After looking in the service manual it appears there are no separate brightness or gain controls for componet but if you still need the service manual I can E-mail it. But once again more sets have been destroyed by a customer just tweaking things a bit in the service menu
Posted on Mar 06, 2008
  • Mike Owens
    Mike Owens Mar 06, 2008
    Ping me at
How much was this tv sold new toshiba tp43h60
Original price of this model was around $1700.
Bill W
Mar 09, 2011 | Toshiba TP43H60 43" Television
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Toshiba TP43h60 - Wondering what the dials are for
You are describing the MASTER SCREEN/ FOCUS CONTROL BLOCK---black with six controls--three are red, green and blue focus--the other three are screen controls--red, green and blue--- the screens are adjusted so with the color off you have normal brightness and a black and white picture--
They have nothing to do with any Convergence problem and unless they have been tampered with rarely need to be adjusted---
I am here to help people.
Oct 09, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 - Unable to adjust colors left/right
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
Oct 08, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Additional info on Toshiba TP43H60
sounds like maybe a fusible resistor has opend. Did you remove one leg of the resistors out of circuit when you checked them? Also some toshiba models had fuseable links near the ICs some mounted between the fins on the heatsink and others were solderd directly to the circuit traces themselves.
Mar 31, 2008 | Toshiba TP43H60 43" Television
what year was your set manufactured. The other site I work for as atech has a vast collection of toshiba service info
Mar 28, 2008 | Toshiba TP43H60 43" Television
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Default service menu codes
They are all different, in every set. Why do peeps not remember to leave these settings alone! sorry but now you will need to have the set serviced.
Jul 11, 2007 | Toshiba 27AF41 27" TV
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60 43" Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
