Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
When turning on my Mitsubishi Projection TV the picture is dark and can see slight images. But when turning on light switch for dinning room lights in adjacent room the picture brightens to normal viewing, when turning of dinning room light picture goes dark again.
The electrical outlet for the TV is separate from the dinning room lights
  • 211 Answers
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Posted on Jun 16, 2009
I have just turned my finlux tv on and there is no picture only sound please help
Since not a brand or model number listed : If its a LCD set get a flashlight and make the room very dark with the set on. Shine the light on the screen at an angle to see if you see a faint image of the picture on the screen.
for more help--model and brand are needed.
Dec 22, 2012 | Televison & Video
Noticable flickering when viewing dark images.
Hello, I too experience this exact same problem. In my opinion, any television under 2 grand is probably going to have some slight imperfection as this; I have tried a few different ones myself. To some, it would appear to only be a minor annoyance, but to those who truly can distinguish a good quality picture between a bad one, or to those people, such as myself, who would find something like this to be unacceptable, this is a disheartening situation.
My friend, I have tried many different settings to see which ones might resolve this issue with the blacks in the picture, or at least reduce it to a barely noticeable level and I have found that when I select the CUSTOM picture mode, reduce the contrast to about 60, turn up the brightness to 62, turn OFF blur reduction,x/v/ color on, CATS on, MPEG NR ON, turn Dark level to LIGHT(this is important) add a little bit of extra color for ex. 52, and sharpness to 75, that this produces a pleasing to the eye performance when watching blu ray movies and dvd's. The flickering is reduced to almost nothing, and the picture quality actually appears sharper and more ethereal in certain ways.
The downside to this is that you are lacking some true depth in the picture's darks, but after your eyes adjust and you are watching a good quality movie, you will notice that there still sort of is enough darks there to compensate. Further fine tuning may produce even better results, jsut have to keep playing around with it. But I am now convinced after hearing somebody come forward with the same exact problem i'm having on the same tv, that it is not a defect but just an imperfection that you sometimes have to deal with when you don't spend like 5 grand on a tv. Good luck and happy viewing!
Jul 05, 2010 | Panasonic TCP42S2 42 in. TV
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Dark over night
Does the TV have a light sensor? If so, turn it off.
The light sensor limits the backlights intensity at night or when it's dark in your room in order for better vieweing convenience.
If you are in a dark environment, it really pains your eyes when the view is too bright. Same works the other way around. If it's day, and light in your room. The light sensor will dimm the backlight for it isn't needed.
Let me know if this solved your question.
Greetings,
DarkNeogen
Jan 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
206 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
