The sms are threaded to one only one number and sms sending doesnt work Whenever I receive the 1st sms on an empty box, all following sms's will show as being received by the 1st sender and any reply will be sent to this first sender.
Ok,so what you should do,is delete some of your threads, and go onto settings and onto SMS counter and up it to 10,000 if your using a smartphone, hope this helped :)
configure the message settings and put the message center number of service provider (u can ask from provider or can copy from other sim/phone who have same network provider sim)
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
To send and receive messages follow the steps:-
1) Go to Options.
2) Select Security Options.
3) Select Fire wall. You will find Block Incoming Messages, Kindly un check all the boxes and save that and you will be able to receive all the SMS.
To make and receive calls follow the steps:-
1) Go to call logs.
2) Press menu key.
3) Select options.
4) Select General Options.
Under this you will Auto end calls, It should be Into holster, Restrict my identity should be Never. Show my number should be Yes.
Try the following steps. I fixed the same problem on my E71 with these.
1. move the sms which can not be sent into the draft box.
2. switch the phone to offline mode.
3. enter draft box, and send the sms
4. after the notification of "saving into sending box..", power off the phone.
5. turn on the phone again, select "no" for the question, then, wait several second, u can see the sms is sent.
Unsubribe To Mozook - Easy n No Charge:
hi to evryone i have a solution just go to this page a deactivate to mozook i have done this ...
Don't waste ur money by following this process:
How can I unsubscribe from the service?
A2: You only need to sms CSUB to 57886 and you will be immediately
unsubscribed or you can enter your number in the unsubscribe box below
and unsubscribe your number after entering the PIN that you will
receive by sms.
Follow this Easy n No Charge process:
Step 1:Go http://www.mozook.com/support.aspx scroll down the u find
"To unsubscribe enter your number here:"
Step 2:Enter your number here:**********
Step 3:Enter the PIN that was sent to the mobile number that you want
to unsubscribe from the Mozook service below and click “confirm” to
confirm your unsubscription request.
Thats it done now ur Unsubribe To Mozook u will get the msg that ur deactivated.
Regards
-Nicky
Try checking the SMSC (Message Center Number) number configured on your phone. If the Message Centre number is not configured or wrong then you will not be able to send..but you can receive.
Check... is there any setting called Inbox Setup in Message menu, then Text msg Setup -> Use GPRS -> NO
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
