Question about EliteGroup P4VMM2 Motherboard
My p4vmm2 want trun on
I plug it in and make sure everthing is right but it just want trun on. help me please
  • 47 Answers
You can check this site where you can check the guide on how to troubleshoot motherboard/ram/cpu
http://www.fonerbooks.com/cpu_ram.htm
Posted on Mar 07, 2008
My 90 Ford 150 key truns on everthing works but dont trun over put new starter solenoid on what could it be ?
you need to check the voltage from the key switch to the solenoid, only if there is power to the solenoid will it work . Once this is correct then the solenoid will click to swittch on the starter motor. If not the starter motor is a suspect, it can be failure of the brush or the commutator.
Jul 07, 2011 | 1990 Ford F150
Can you please help me find drivers for my motherboard p4vm2...
You can find your drivers here:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=P4M266A
You also need to know what rev. number it has to get the right driver.
It should be typed in on the mainboard.
Keyword:p4m266a Total:3 1. P4VMM2(V3.1)
BIOS - 1. Support VIA P4M266A chipset...
2. P4VMM2(V7.3)
BIOS - check sum:9B87 h 1.Support P4M266a CE...
3. P4VMM2(V7.1)
Good luck.
Feb 25, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I need all drivers for my motherboard.P4VMM2 and i
Hello
Thank you for using Fixya!
You will be able to download al the drivers (Up to Windows XP) at the link below.
Click HERE to navigate.
The fact that the Ram ports differ in colour actually means that your motherboard supports Dual channel ram. Basically this means that if you have 2 ram modules, you need to plug then in either the Back, or the Blue ports for best efficiency. Do not plug one into the black, and one into the blue.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Feb 21, 2011 | EliteGroup P4VMM2 Motherboard
My literati ereader wont turn on
Just called customer service and got a fix. Plug in the recharger and insert a needle into the reset hole, hold it for ten seconds, release. Wait until you get to the main screen to make sure everthing is all right. My unit was not recharging even though it was plugged in. So I'll be going to the store of purchase for a replacement.
Dec 27, 2010 | Sharper Image Literati Reader 16375680042...
Had to replace distributor need to set timing,need basic timing degrees? its a 98 dodge dakota 5.2l
Take the number one plug out and put a screw driver in the hole and trun it over by hand till the piston hits the screw driver and then take the screw driver out and trun it just a lil more. Then when you put the distributor in make sure there Is a rotor on it and face the ponit of the rotor to the number one piston and bolte it in and you may have to turn it lift and right to get it right one time. Hope that helps.
Dec 17, 2010 | 1998 Dodge Ram 1500 4WD
I need some help please my computer has no sound! and I don't know my sound card driver how can I install the driver of my soundcard, my Operating System is Windows XP.. INTEL PENTIUM 4
open devices manager(in run type devmgmt.msc)in that right panel right click and select scan for hardware change and select search automatically finally it ask whether do u want to search in internet now click ok.
Nov 25, 2009 | EliteGroup P4VMM2 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
ECS P4VMM2 driver
I lost my ECS P4VMM2 motherboard driver, and i need the driver to work my pc completely...
Aug 11, 2008 | ECS RS400-A (V1.0) Motherboard
PIN LOCATIONS
Hi raul27
You can download the entire manual for the mobo here
Thanks for using fixya, any dramas working it out, please get back to me here
robotek
May 05, 2008 | VIA P4MA Motherboard
EliteGroup P4VMM2 Motherboard Logo
21 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
