Question about Kodak EasyShare Z740 Digital Camera
Flash will not work.
Even though the flash is open, the screen still shows the flash is unavailable. I tried pressing the flash button, but it will not change. I tried changing modes, batteries, lighting conditions, but still no flash.
  • juan2007 Apr 09, 2008
    My cameras flash dont work at all even when in saids it does..
  • Stephen Newton
    Stephen Newton May 04, 2008
    Is there an actual solution for this or do I have to just send the camera off to some repair shop?
Posted on Apr 12, 2008
How di I manually pop open the flash
Press the OPEN (flash) button.
This button is on the side of the camera just below the flash.
The flash mode button (lightning icon) is at the lower left on the rear of the camera.
This only changes settings when the flash is up.
This cycles through Auto, red-eye reduction, forced flash and no flash.
The mode shows in the finder or the LCD screen.
AUTO mode does not show.
Oct 20, 2014 | Sony Mavica MVC-FD95 Digital Camera
How do you turn the flash off on a hp photosmart 435 camera
Hi hookerglen.
NOTE The flash does not work while recording video clips.
To change the flash setting, press the Flash button on the top
of the camera until the desired setting appears on the Image
Display. The camera remains in the current flash setting until
you change it or turn off the camera.
please fellow the instructions in the picture bellow aid you use your hp cameras flash light better.
let me know if it works for you.
May 11, 2011 | Cameras
The flash pops up, but it doesn't flash
It is normal that when you press the shutter button half the flash won't fire because you're focusing on a subject upon pressing the shutter half way
It's just like you are locking a subject upon pressing the shutter half way
Aug 23, 2009 | Canon PowerShot S1 IS Digital Camera
I have a brother printer 2140 and the drum light stays on :0
You have to open the door and hold the go button til all lights flash. That tells the printer it has a new drum. After that press the go button 3 times and it will print a report that shows the drum as new...
Jul 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Sonyy w55 flash works but shot come really dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Help flash Nixon coolpix L11
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
T830 flash rom
I to all, sorry for my english. I have resolved this problem, with the PocketLOOX8xxFlashTool.exe. The tool first try to connect to the T830, then it show you how to reset the PocketLoox to reflash it. The sequence is:
1) Reset by pressing Power Button + camera button + factory reset; 2) insert the usb cable in the T830 or insert it in the docking with the Power Button + camera button pressed. When you insert the usb cable, on the screen it show a new message "New USB download mode". Now PocketLOOX8xxFlashTool.exe can connect to your t830 and reflash it.
Good luck
Sep 16, 2007 | Fujitsu Siemens Pocket LOOX T830...
Flash won't work - possible bulb failure?
Check Kodak for repair quotes likely hood not economical though
Aug 07, 2007 | Kodak EasyShare DX6490 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
177 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
