Question about GE GSL25JFPBS Side by Side Refrigerator
GSL25KGREBS FRIG First my waterline stopped working, but I have great spring fed tap water so I ignored it (the icemaker still worked). Now, the ice & outside light won't work either and the fridge has started to click & the light inside flickers with the clicking, I noticed a fan in the freezer is also moving slowly to the clicking. It's still cold inside the freezer & fridge?! HELP?!
  • 3 more comments
  • Shannon Susak Friel
    Shannon Susak Friel Mar 08, 2008
    We tested the valve to find the red reads 183 & the blue reads nothing. So we'll go ahead and replace it. However, the ice dispenser still does not work? We assume this is whole other problem?!
    How do you test the actuator? Thanks for all the help!
    Shannon Susak Friel Mar 15, 2008
    Ok, water inlet valve replaced-everything is the same. When we had the fridge pulled out we noticed the clicking came from the area of the computer panel. We also noticed the fan at the bottom stop in repitition with the clicking-not just the freezer evaporator fan. When we push on anything in the dispenser area it clicks twice in back. Is there anything else we can check?!
    Shannon Susak Friel Mar 21, 2008
    It's a side by side and we just went ahead and called a service guy. He had to replace the computer board & everything is back to normal...
    We just went ahead & called a repairman-he had to replace the computer board and everything is back to normal
    Master:
  • 377 Answers
Frost free refrigerator models with a top mount freezer utilize a drain to take the water melted off the coils to the evaporator pan. This pan collects the water in the bottom of the unit and uses the heat of the compressor to increase the evaporation rate. If this drain becomes clogged with ice or debris it will back-up and eventually over flow. This overflow usually collects in the bottom of the fresh food compartment below but can also leak onto the floor.
Posted on Mar 20, 2008
  • 4,889 Answers
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
  • 1 more comment
  • eagle338
    eagle338 Mar 20, 2008
    Do let me know whether its fixed so that we can proceed further..
  • eagle338
    eagle338 Mar 21, 2008
    Did you resolve the issue? Please post back so that we can assist you further..
  • eagle338
    eagle338 Mar 27, 2008
    Good to know that you have got it fixed.. cheers!
    Sergeant:
  • 279 Answers
There are two things that could be causing this. First I would check the water inlet valve. There are detailed instructions for that here, along with images: http://www.acmehowto.com/howto/appliance/refrigerator/check/inletvalve.php
It's likely that water isn't getting into your system. As the ice pulls water slowly, it would still work with a partial blockage, where as your water delivery system wouldn't - it needs a stronger flow. I'm guessing the valve is completely blocked by now.
The fan should also be tested. Detailed instructions on how to do that, with images, can be found here:
http://www.acmehowto.com/howto/appliance/refrigerator/check/evapfan.php
Of course, if both of these are having problems, it could also be a power related issue. They run off a different level of current than other components of the refrigerator, so it's possible the power supply is damaged. If you test and find that the inlet isn't blocked and the fan is working, I would check the power supply.
Of course, the images above aren't from your model, but they should be similar enough to follow.
-Dyllan
Posted on Mar 06, 2008
  • John Goodman Mar 09, 2008
    Actually, the ice dispenser feeds off the same line. It's probably the same problem. Once that valve is replaced, let me know if the ice machine starts working again. If it doesn't, we'll look into other things, but until we know it's getting water it would be hard to tell if there was something else wrong.
    -Dyllan
    Brigadier General:
  • 3,614 Answers
Defrost the fridge.. It might possibly the dry ice makes the fan not move,and possibly make a hramful effect to the motor,
Why doesn't our new icemaker in a whirlpool ed5 fridge work?
Make sure water line valve is turned on where it taps in to water line,and that ice shut off is down not up, check to see if water is in ice tray or if it is dry if no water or ice is present then water is not getting to it if water tap valve is open then water valve in ice maker is off or ice shut off arm is up instead of down. Try pouring warm water in ice tray see if that will get it started.
Jul 21, 2014 | U-Line Icemaker
Have a new frigidaire how long does it take for ice bin to fill after waterline install
Ice maker will call for water 12-14 hours after plug in. If the ref was running and then Waterline was connected it should call for water in 4 hours or less. Easy rule, after 24 hours, ice bin should be full.
Dec 05, 2012 | Refrigerators
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Even though I connected the waterline,there is no water in the ice maker. the icemaker keeps turning to dispose the ice it does not have. Thinking that the end of waterline was frozen, I unplugged the frig...
BACK OF THE FRIDGE IS THE WATER VALVE. UNPLUG THE OUTLET WATER OF THE VALVES, LEAVE THE INLET CONNECTED. APPLY 120 TO THE VALVE AND SEE IF WATER COMES OUT. MOST LIKELY YOU HAVE TWO VALVE, WATER AND ICE. IF THEY BOTH WORK, YOU HAVE A BAD MODULE IN THE ICEMAKER
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice Maker has stopped working....not sure if water is reaching ice maker. Would this be a difficult fix?
Depends. Put your fingers into the icemaker. Feel for ice or water. If none, check the fill tube to ensure it is not iced up. This tube feeds the icemaker with water. If it is iced up, thaw it out. If no ice or water in icemaker then pour a cup of water into the icemaker, wait the nite to see if it drops the ice. If it does the problem is the valve behind the frig.
Feb 08, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
I hooked up my refrigerator and my ice maker to work. I've checked the waterline. But no water comes out of the dispenser and no ice is being made.
i had the same problem one time and there was something obstructing the fan under my frig and i blew thru it to icemaker with compressed air and it started working
May 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Kitchenaid Icemaker with Aqua Sense is not working.
If the freezer was shut off for a time, then the water in the feed tube may have frozen when the freezer was turned back on. Check to see if there is ice in the mold. If empty, then the feed tube is clogged or frozen (or else the water inlet valve may have failed, less likely).
Feb 26, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE side by side GSL25KGREBS
Same problem here. Called local service tech and he said it was a common manufacturer defect with some GE refrigerators. I called GE and they don't have a recall or any formal documentation available to Cust. support people but found this on another site. A Replacement Program my GE, letter to GE service techs regarding problem. My model was listed and i am ready when the GE tech comes tomorrow that he knows about it.
here is link:
http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Mar 17, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
