Question about Sony SLV-D360P DVD Player/VCR
Problem When unit is plugged into electricity and power switch is pushed,nothing happens.No light nor anything else.I checked the fuse which appears to be alright but replaced it anyway. May have taken a power surge due to lightning.Noy sure.No obvious damage visable.Any suggestions?
  • Trutyj Mar 05, 2009
    I have the same problem, fuses are okay, power cord is al right. Nothing seems to be burned or damaged. Was working yesterday and now wouldn't respond and no display in the front of the system (where clock shows). Also the system doesn't respond when i press the eject buttons.
    Any ideas?
  • 2,130 Answers
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 06, 2008
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Feb 27, 2011 | Vacuums
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
I cleaned my Ecoquest, it was working fine, how no power
Assuming that the unit was working fine before you cleaned it. Did you remove the back lower panel while cleaning it? It the panel that holds the electrical socket and fuse. If you did, check to see if the electrical connector is seated to the main board. Also check if the keyboard connector (the one that looks like a telephone jack) is plugged into the main board. Also, check if you model has a switch on the back that it is set to the on position. And press the power switch on the front keypad to see if that make the unit work. That all I can think that might have gone wrong.
Jun 30, 2010 | Ecoquest Fresh Air Air Purifier
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Jun 02, 2010 | Maytag Heating & Cooling
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Feb 28, 2006 | Panasonic SC-PM19 CD Shelf System
Sony SLV-D360P DVD Player/VCR Logo
648 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
