Question about Lexmark X2500 All-In-One Printer
Alignment problem when i want to print a document , a thing pops up and say alignment error.i can not fix this
  • Anonymous May 31, 2008
    printer alignment error
  • fjgml Nov 14, 2008
    I get a message that there is an alignment error,try manual alignment which I did, but it still misses text and graphics
    Genius:
  • 3,587 Answers
Actually, you need to run a test alignment page from the printer menu or if you have the lexmark print manager, you might be able to do it from there..
Posted on Mar 11, 2008
Alignment problem error message.
It could be due to cartridges in the printer. Try the steps below to identify and fix the problem:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try this approach:
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 4200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page that will help align the cartridges.
Feb 10, 2012 | Lexmark X4270 All-In-One InkJet Printer
Alignment off
If that doesn't help, please try this approach:
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Printer is printing blurred documents
It could be that your cartridges are not aligned. Please follow the steps below to fix your problem:
  1. From the printer operator panel, press the Setup button.
  2. Go to Maintenance.
  3. Select Align Cartridges. Your printer will then print a page to align your cartridges.
  4. After the test page is printed, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Oct 19, 2011 | Lexmark X4650 InkJet Printer
Says error 5200
Canon have a website. I could not locate the error you mention above so the link below is to the error list:
http://support-au.canon.com.au/contents/AU/EN/8200169800.html
If you cannot locate your error there, use the link below. You can get Manuals, FAQ, Downloads etc... for the Pixma MP240.
http://support-au.canon.com.au/EN/search?v%3aproject=ABS-EN&binning-state=model%3d%3dPIXMA%20MP240%0Amenu%3d%3dQA&
I hope this helps. Please rate. Regards,
Feb 22, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Changed the black printer cardtridge on a canon mp160 and getting errror code E19 when trying to align the heads...any idea why, and how to fix please? Thanks
This error idicates that the size of the document cannot be correctly detected or the document is too small when the Fit-to-Page copying is selected or the unit Failed to scan head alignment sheet correctly.
The remedy is
Make sure the document meets the requirements and correctly loaded on the Platen Glass. Then reload the document and press the Black or Color button.
Check that all necessary circles are filled in the Print Head Alignment Sheet, and that it is placed in the proper position and orientation on the Platen Glass. You can also perform print head alignment manually.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell A960 AOI Printer problem
Have you reset the ink levels for your printer? Some printer software refers to it as that others ask if you have installed a new cartridge.
Do maintenance on the printer, such as clean heads, print test page, head alingment, etc and see if that fixes it. You can get to all these options through properties
Sep 30, 2007 | Dell A960 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
