Question about Nokia 6103 Cellular Phone
Insert SIm, Unable to backup data
Is there a way to activate Infared or Bluetooth while the phone will not
recognize the sim card? I need to backup some stuff off of the phone.
  • billdunk Mar 07, 2008
    Thanks, that part is broke.
  • 492 Answers
A sim is required to run any part of the phone.
Posted on Mar 07, 2008
On my tracfone all that comes upisinsert SIM what is this?
Troubleshooting > SIM Card - Tracfone
www.tracfone.com/includes/content/.../General.jsp?...
TracFone WirelessHow do I install my SIM card? You will need to remove the ... This message appearswhen a SIM card from another phone is used. Please make sure to insert ...
Surprises of the TracFone SIM Card.
www.best-prepaid-cell-phone-plans.com/surprises-of-the-tracfone-sim-ca...
Now I can store all my contacts on it, so when I upgrade to a new phone I won't have to re-key. ... $28 comes with 90 days service, minutes, data & 6 sim cards. .... I thought I could transfer my numbers to the old SIM card and insert into the new phone. ... You have to call up Tracfone and they will mail you a new SIM card for ...
How to Activate a TracFone - The Tech-FAQ
Dec 03, 2015 | tracfone.com
Backup contacts
Buy a new SIM card, insert in the old phone, copy all contacts and transfer them to the new Phone.
Works if you have less than 250 Contacts due to capacity of the SIM card.
If you have more than 250 contacts use bluetooth transfer or memory card
Jan 23, 2014 | Facebook Social Network
After charging W350i not recognising SIM says, 'Insert SIM Card'. But the same SIM card is operative in other mobile. How can retrieve Phone contacts? Please help.
make sure if sim reader is not pin damaged or water damaged? if problem persist i think you can connect your device without simcard and copy all data to your pc, then give some repairer to check maybe need to flash (if flash you will lose your data).
or try to put your mobile without battery 2 days and then switch on to see may be this problem solves.with S.E. this problem a normal.
Jun 21, 2012 | Sony Ericsson W350i Cell Phone
I have not used my boost mobile i335 in over a year. the battery is charging but it says insert sim. The sim is in there why does it still say for me to insert the sim?
Thanks for visiting FixYa!
The message you are receiving 'Insert SIM' is due to the SIM card not being registered. (ie., it was registered at one time but is not now.) As such, it cannot receive network information. And, your phone sees this SIM as nothing more than a piece of paper stuck in the SIM card slot.
A single SIM card is not used to activate - and then reactivate - an account. To get service on the phone, a new SIM card will need to be purchased.
If you're in doubt as to whether your phone will recognize a SIM, take your phone to one of your cellular provider's stores and let them test it.
Feb 16, 2011 | Motorola Mobility I335 Cellular Phone
When i put in my sim card the screen says 'offline' insert sim. The sim card is already in the phone. I can't make any calls, only emergency calls. I can't recieve calls either.
Many of the newer cell phones (for some unknown reason) will not accept - or even recognize - a SIM card if it has been used in another cell phone.
Contact your cellular provider's customer support dept. and request you be sent a new SIM card. When you get it - activate the SIM first before putting it in your phone.
Jan 25, 2011 | Cell Phones
'Insert SIM'
If you are trying to use an old sim-card from another phone you may find that it won't recognize it.
The older sim cards just aren't up to the job the newer handsets require so now we have more powerful and higher voltage sim-cards.
Try a sim card from a friend with a new handset and see if that works in your phone.
You may have to go get a new sim.
Jul 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
Nokia 6110
ahh the notorious "sim not read" error message
well what you have is a is a faulty contact issue from the phones brass 8 or 10 pin points to the sim card pin contacts inside the phone itself and also too, your service provider has without your knowing it, from time to time have uploaded numerous software data updates to your phone, and often old sim cards, if not replaced occasionally, your sim card has a compatibility issue to the new data being sent to your phone. You basically need a new sim card. Usually and often if the phones has suffered a lot of abuse (from physically dropping to the ground and natural elements like tempertature, rain, exposure to cold and moisture, which is a big culpret) those brass contacts,located inside the phone, that are on the edge of the sim card (when you turn the sim over you see them) get particules in between the contacts causing the notorious "sim not read" or even the notorious " sim not found please insert sim".
Nov 02, 2009 | GPS
When your sim card is already in your phone, but then suddenly it just starts saying insert smart chip...what does that mean.?
Insert SIM card means that the SIM is not seated correctly. It may not be locked into place and got jostled around when you plugged the phone into power. This message would not relate to a battery going dead, only to the device not recognizing the SIM card and that would only be if the SIM was not activated (which you know that it is active) or if it is not properly seated (locked down, etc.). Make sure that the SIM is properly seated (look at the manual to be sure) and then you should be okay. If this is not the case, and the SIM is properly seated, then the device is defective, broken or the unlocking caused faulty errors.
Jul 17, 2009 | LG Vu CU920 Cellular Phone
How do I change the SIM card in my BB Pearl 8130
Take SIM card out of old phone and put it into the new phone, however first of all you need to backup your old device.
Download the Desktop Manager and connect via USB cable and backup old handset, insert usb into new phone and restore to new phone thus moving all data from old to new.
Gadget
Dec 03, 2008 | RIM BlackBerry Pearl 8100
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Nokia 6103 Cellular Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
