Question about Refrigerators
Termperature Control I recently purchased a Danby model DKC586BL beer cooler. Unfortunately it doesn't keep the beer as cold as my last one ( an old Sears unit). The lowest set point on the digital display is 34 degrees. It then cycles between 34 and 37 degrees. I'd like to have a set point of 30 or 32; peferrably 30. I know beer freezes at 28 as the control unit went bad on this new unit and the display was showing less than 28 degrees. Danby replaced the control unit with a new one but the beer is still warmer than I'd like. Is there someway to modify the control circuit to allow for a lower set point?
  • 3 more comments
  • zman2 Mar 10, 2008
    Not the thermostat. Danby agrees the set point is as low as it can go by design. I need to modify the circuit which they will not do.
  • zman2 Mar 25, 2008
    I basically did over the weekend what is detailed in the repsonses. I bougth a Johnson Controls mechanical temperature control( model A19 ABA 40C with remote bulb) with sensing bulb and capilliary. With the power off I cut the output feed of the controller to the compressor and capped the control board end off with wire nut. I then ran a two conductor wire from the new controller and tied one end to the compressor feed and the other end I spliced into the control circuit board power infeed. This leaves the circuit board powered for display purposes but no longer controls the compressor. I set the new controller to minimum differential (3 degrees) and 32 degrees on the scale and let it go. 24 hours later iced cold beer at 32 degrees. AHHHHHH isn't life grand. Cold Beer.
    See my reply above. But Danby uses a solid state thermister feeding into an ROM chip circuit which is pregrammed at the factory and ROM chips cannot be repgrammed. So technically the whole circuit board card is the thermostat. I just bypassed the whole mess.
    The unit is new <6 months old. I bypassed the control circuit with a different style controller.
    Poor design that will not allow a lower temperature. See my comments above.
  • Refrigerators Master
  • 19,396 Answers
Well, the control circuit get input from thermostat.
what you need to change is right the thermostat. I do not think there is any way to lower fridge temp if you do not replace thermostat.you could put an additional switch to turn on/off manually the compressor when you need extra cold, but in this way you risk to damage the motor.
You need to change the thermostat with one that switch on at a lower temperature. to do this you may need to use a non-fabric part.
regards
Posted on Mar 20, 2008
  • 1 more comment
  • Ginko
    Ginko Mar 20, 2008
    The thermostat is the switch which starts the motor back when your fridge goes down to 34.
    If you want the fridge start cooling at 30 you need to get a thermostat that can start at 30, and presumibly you will need to adapt a different brand one.
    This has nothing to do with control board.
    Regards
  • Ginko
    Ginko Mar 20, 2008
    Regards
  • Ginko
    Ginko Mar 20, 2008
    There is no circuit that you can modify to get lower temperatures, as Sweet rascal said, change the thermostat, it is the switch that check the temperature and start cooling process. Danby told you not to change the thermostat because in their perspective you are not supposed to change any fabric part in your fridge.
    If you do the thermostat replacement in proper way it should work, however I suggest to think double before modifying fridge in this way. By using non factory replacements you risk to damage the fridge.
    regards
    Master:
  • 377 Answers
I suggect to check the coil, it needs to be clean it will prolong the life of your refer and allow it to run more efficiently.
  • 4,889 Answers
Hi zman.. the circuit does not recognise what kind of thermostat is used.. it only breaks the circuit depending on the thermostat.. So as sweet rascal has suggested you get a new thermostat which can cut off at 30.
    Guru:
  • 1,894 Answers
Hello sir
Posted on Mar 10, 2008
  • dewan nafees ahmed Mar 10, 2008
    the thermostat must nott be working well...
    replacing it ll solve the problem
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Foamy beer
Keg's are normally pressurized at 13 psi. If you only set yours at 8 psi then you are going to cause problems. You should always start at least the same psi that the keg is set to. If you can talk to the keg company as they all differ some. Common problem is to lower the psi which will cause foam until you reach about 1/2 full or a little less then you should get less foam but your beer will become very flat. Too much pressure is usually better than too little, even with too much pressure you'll see the beer come out fine but will start to foam when hitting the glass/pitcher. Also note that the coupler's that Danby use are very cheap, check the CO2 vale (between CO2 line and coupler) to see if there are any cracks or anything.
Sep 27, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Refrigerators Logo
462 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
