Question about Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS
Mead Lx90Gps 8'' handbox is dead
Hallo, assistance needed!
We have the same problem. Our handbox did not function after possible reverse polarity event. Red light is still on but seems a litle darker as must be. Must we need circuite board change?
Thanks in advance!
    Guru:
  • 1,894 Answers
Hello sir
Posted on Mar 07, 2008
  • dewan nafees ahmed Mar 07, 2008
    yes..
    change the circuit board..
    this wil surely fix you
    thank you good luck
    dont forget to rate the solution
Chevy engine wont start
Did they reverse polarity on you ? It's possible that they did just that, and when reconnected it, fried your electronics.
Jul 23, 2014 | 2005 Chevrolet Silverado 1500 2WD
Why does the hand controller light up then goes dead
Possibly poor connection to the scope. Known issue. Go to
Weasner Mighty ETX Site for tips on repair
May 25, 2014 | Meade 494 AutoStar Telescope Control Unit...
Ok well my battery was bad and my sister tried tosuprise me with a new one but put it in backwards hooked it up now i need the battery fuse link thing but we used a temperary fix till i get the part but my...
The reverse polarity will have "zapped the radio"
There is a possibility that only the supply fuse has "blown", but depending on the radio make, could have blown the internal fuse as well.
Also, there is again the distinct possibility that other supply circuits failed with this Reverse polarity energy supply.
Work across each supply circuit in turn, now the Battery is connected properly.
Ignition warning lights, gauges etc.
Headlights, Turn signals.
Wipers, washers.
Remote locking, Alarm.
Engine startup, Alternator charge output.
A/c operationand Heater/Blower controls, and function.
Best of luck.
Regards, DT
Mar 14, 2011 | 2004 Mitsubishi Endeavor
My 8" LX200GPS won't turn
Then it is an internal circuit board issue. Something is either unplugged inside the scope base-- or is burned out. Meade can repair these call them:
http://www.meade.com/support/index.html
Dec 30, 2010 | Meade LX200GPS Telescope
Getting lots of splatter weld will not hold
Check polarity of machine.
Solid wire with gas assist will need straight polarity ground clamp to negative side.
Flux core wire no gas, need reverse polarity; ground cable to positive side.
Oct 27, 2010 | Clarke Power Products Clarke 130EN...
I installed replacement batteries with the polarity reversed. Since then unit does not display the Contact file, but all other functions (activities, data files, etc.) seem unimpaired. Any ideas? I...
Hi, well the reason this has happened is that these contacts are stored in battery backed up NVRAM, now this RAM is very sensitive to polarity reversal, and also due to the way it works, doesn't have polarity reversal protection, on that circuit. So when you reversed those batteries even though the reverse polarity protection saved the Unit as a whole, the NVRAM would have been destroyed or wiped at best. These is no real way of replacing this NVRAM, I guess you could send it back to the factory though and ask for a "Quote" with view to the repair.
Sep 14, 2010 | Sharp Zaurus ZR-5700
The dec, knob must have streped on my 2000 LX90.
Look at this for a possible fix--
http://www.scopestuff.com/ss_ezck.htm
Jun 23, 2009 | Meade LX90GPS: 8" LX90 GPS Telescope
LX90GPS "finding north" does not complete
The LX90GPS and other LTN devices use an internal accelerometer to calculate tilt and North. That has nothing to do with the GPS. Sounds like you need to talk to Meade.
My LX90GPS doesn't do North very well, but I can calibrate that out with the two star alignment. THEN the thing points almost perfectly all over the sky. Sorry I couldn't help you more.
Jul 16, 2008 | Discovery Channel Meade 8" LX90-GPS...
Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS Logo
118 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
