Question about Proview PL576Ws 15.4" Widescreen LCD Display
Error Message My monitor operates perfectly other than an error message that will not disappear. The error message is, "mode not supported" on the first line then, "H:56.4KHZ V:70.OHZ" on the next line. How do I correct this?
  • 558 Answers
In windows display you need to set the display refresh rate to 60. you will find it "right click on desk top, select properties, select settings, the select advanced, selects monitor and change the refresh rate to 60 hz
Posted on Apr 28, 2008
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Error message 000450F2 and 0xc0000142
i cant give any help without an error message problem
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Oct 01, 2012 | Dell Dimension C521 PC Desktop
Dell LCD Monitor will only work in safe mode - otherwise I get the error message Can't Display this Video Mode. I have reset to factory settings and also tried manually setting it to 1280x1024. When...
This Dell E153FPf 15" TFT can olny handle max 1024 x 768 @60Hz that is why you are getting the message ont the screen.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 03, 2011 | Dell E153FPf 15" TFT LCD Flat Panel...
Emachine monitor (eview 15l, model 568) will only show a ''VGA NO Support'' message. Menu button also not cooperating. Computer works well with a different monitor. Fixable?
I have the same monitor and get the same error message. To fix it I went to
"Display Settings" then
"Advanced Settings" then
"Monitor tab" and set the refresh rate to 75 Hertz Then go to
"Adapter Tab" and select list all modes
Find a setting with 75 Hertz mode and and the resolution you want
and select Accept Good luck!
Jan 12, 2010 | Computers & Internet
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Check:-
Fan,
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
Proview PL576Ws 15.4" Widescreen LCD Display Logo
94 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
