Question about Frigidaire FEQ1442ES Electric Dryer
Won't start/tumble when start button is pressed - error code 95
My biggest problem is that no one seems to know what error code 95 means.
  • 315er Mar 11, 2008
    Never found out what error code 95 stands for "officially". When I contacted Electrolux - Frigidaire they only suggested I contact a "qualified" service technician". Someone at this site suggested the circuit board. First, I checked the door latch and thermal limiter for continuity and both were good. By process of elimination I figured it was probably the control board and ordered one through Electrolux (total cost with NYS tax and S/H was $126. Dryer works fine now.
Circuit board problem
Posted on Mar 06, 2008
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Won't turn on
If power light comes on for a few seconds and goes off: on front of set press and hold both the Menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Please let me know what error code you find and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65511 65" Rear Projection...
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 04, 2010 | LG WM2277H Front Load Washer
Error code LE
If you are getting a "water inlet" error "IE" I found out thru trial and error that my inlet valve(s) were messed up. On my particular machine you can put the machine in trouble-shooting mode by pressing the "Spin Speed" and the "Soil Levels" at the same time and press the "Power" button while doing that. Then advance thru all the functions by pressing the "Start button"
1 time; Tumbles clockwise,
2 times Low level spin,
3 times; High speed spin,
4 times Inlet valve for prewash,
5 times; Inlet valve for main wash,
6 times, Inlet valve for Hot water,
7 times: Inlet valve for softner,
8 times; inlet valve for bleach,
9 times; tumble counter-clockwise,
10 times; turns Heater on (if equipped)
11 times; circulation pump,
12 times; drain pump,
13 times; power off and unlocks the door
Good Luck!!!
May 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Frigidaire FEQ1442ES Electric Dryer Logo
264 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
