Question about Acer Aspire 3004WLCi Notebook
Slow connection w/ FiOS
I just got Verizon FiOS installed and it works fine as long as I'm close to the router, but the further I move away, the slower internet sites load, sometimes they don't load at all.
My speed is always somewhere between 24 and 54 mbps
I've an Acer Aspire 3004WLCi - 802.11b/g wireless LAN
my comuter was set to 802.11b, but since the modem runs on 54g I changed it to 54g Performance - it didn't help
Is this a problem with FiOS or with my computer? How can I fix it?
    Brigadier General:
  • 3,614 Answers
You may not be interpreting the LED correctly. The Link LED goes on to indicate a physical connection (if the Link LED is out, the cable is damaged or disconnected), but the 10/100 LED only illuminates when there’s a 100Mbps connection. The LED will remain off when the connection is only 10Mbps. Here’s how to quickly determine the speed of your connection. If the 10/100LED is off, there’s a slow connection. If the LED is on, there’s a fast connection.
A fast (100Mbps) network connection requires that both ends of the connection support 100Mbps communication. So, if the 10/100 LED on your hub is dark, chances are that your PC’s network adapter (or NIC [network interface card]) is only operating in the 10Mbps mode. Check the NIC in your Device Manager Network Adapter entry and look for any 10/100 designation. An older 10Mbps NIC may need to be upgraded for 100Mbps operation. If it’s a 10/100 NIC, refer to the PC’s documentation and check the NIC settings to make sure it’s not locked in the 10Mbps mode. Set the NIC to a mixed or 10/100 mode so that it can adapt automatically to establish the best possible connection.
Posted on Mar 06, 2008
    Master:
  • 377 Answers
Hehehh..
Posted on Aug 16, 2008
Can i use a Bright House Surfboard Router for Verizon FIOS Internet?
If you can reset all the parameters, however if you know all the info I would suggest that you use something like a Belkin. You need the IP "name" for you, the connection password, and you really need to know what you are doing.
The only ISP that cannot easily be used with another modem is Sky as they deliberately use a different encoding. Yet again another reason NOT to use sky, it is difficult to monitor, and to use other equipment.
Aug 02, 2014 | Motorola SURFboard Computers & Internet
Wireless network very slow. We are fine when hard wired into the router but when not it's painfully slow. We have a Verizon fios wireless router westell 9100
Make sure you are connected to your network on wireless and neighbor's
open a browser and go on to www.speedtest.net
click to check your internet speed Fios is pretty fast!
Your wireless if connected to your own network the speed is comparable weather wired or wireless!
Try these steps and let us know the results to further help you!
good luck
Sep 11, 2011 | Computers & Internet
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
FIOS Internet connectivity problem with Toshiba Satellite 105
Is your laptop running Vista and the desktops running Windows XP or they all running the same software??? Also your problem is the fios router they come set up to be on a automatic channel search so there always searching for the best channel and you probably live in a brick house....Go to the settings for the router you can get to them easy with the software they downloaded to your computer its the fios help icon on your desktop and you can change the routers channel go to 7 or 11... If you have any questions just let me know also please rate me if you get a chance..
Thanks,
Steve
Dec 17, 2008 | Toshiba Satellite A135-S2246 Notebook
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Acer Aspire 3004WLCi Notebook Logo
318 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
