Posted on Mar 07, 2010
ScanGear Internal Error Code:5,202,54 - Canon Office Equipment & Supplies
paul wilson
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 18, 2014
paul wilson
Contributor
Level 1:
Answers
Questions
0
Helped
9710
Points
0
All i am getting is advertisements that can "fix" my computer at a price, everywhere says there is a driver out of date but nowhere tells u how to fix it
its a cannon mp250 throwing up error5,202,54 when trying to scan
2 Related Answers
Anonymous
  • 70 Answers
  • Posted on Nov 29, 2009
SOURCE: Canon MP250 printer scanner in a canning mode
Go to Device Manager at USB Controllers and disable Standard Enhaced PCI to USB Host Controller. If you can't find exactly this, disable the one with the word Enhaced in it. Right click it then click disable.
Anonymous
  • Posted on Jan 07, 2013
SOURCE: I have a canon mp250
ive been resolving that issue for almost 8 hours since last night.(that means i did not sleep) because i badly need to scan papers for my precentation today. finally it worked after unstalling all canon folders, then reinstall everything... hope this work with you
Code 2,250,200
Re: Error code 2250,2 or 2155,33 on scanner 9000f - Canon ...
community.usa.canon.com/t5/Printer.../Error-code-2...2.../123789
Nov 6, 2014 - Dear all Canon staff, I brought my 2 years ago. And I had not used it for around 1 year. When I used it again, Scangear run out error code 2,...
1helpful
Scangear internal errot code 3,202,19
try restart PC, change USB port or reinstall a driver
SCAN GEAR INTERNAL ERROR CODE 5,202,54
This is a well known problem. Users have often asked Canon to fix it but the development team never provide a fix.
2helpful
5answers
Internal error code 5, 202, 54
Perhaps you have forgotten to unplug the scanner before scanning? That's what happened to me. I kept getting different error codes, 5,202,63 or 5,202,52 or 5,202,54 and also a message that the driver was not in the TWAIN folder. According to the help file the problem might have been due to my nfts file system. I also tried downloading various new drivers. Nothing helped until I noticed that I had not unplugged the scanner!
I have a canon mp250 the printer & copier work fine but i can't scan. This is the error that comes up. Internal error occured Scanner driver will be closed Code: 5,202,54 what should i have to...
4helpful
2answers
Internal error occured code: 5,202,52 after installing Canon CanoScan Lide 210
13helpful
2answers
Scan gear internal error occured code: 5,202,52
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon LIDE 110 Scanner cause I was so mad that it gave me this stupid error (5,202,52) no matter where I was connecting it and I thought it was done...
THEN I just took another USB Cable (Like I have around 10 different USB Cables) ...AND IT WORKED! Try several USB cables before you give up on it...also don't start messing around with drivers and stuff, you could end up screwing up your system like I did...
I hope this helps someone out there in the future with error 5,202,52 or 5,202,54, etc.
Try at least 4-5 different USB cables before anything else..
(If you want to know, I successfully used the USB cable with one of the fat black circle things on it (I think its for power or something), not just a straight usb cable. It's still a 5 pin USB cable however (Regular USB on one side, small 5 pin connecter on the other side))
5helpful
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
old marine
old marine
ZJ Limited
ZJ Limited
