Question about Minolta bizhub 200 All-In-One Printer
Fusing unit error c3451
  • parish6 Mar 06, 2008
    can this be fixed without a repair man
    Scholar:
  • 141 Answers
This is a fusing warm-up failure....Check if you don't have a paper stuck in it...but be carefull because it 's very HOT...
Check if when you put the copier ON that you see ligth in your fuser...because you may have a bad heater lamp.
And if you don't have a paper in it and it won't reset by opening and closing the front door you may won't to call a tech ! Because you will need to replace one the sensor inside your fuser.
Posted on Mar 30, 2008
Konica minolta bizub 164 call service c3451 tell how solve
Warming-up failure
1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Jan 13, 2015 | Konica Minolta Office Equipment & Supplies
My xerox machine model is Konica Minolta Bizhub 164. machine trouble service call (C3451) showing on display. what should i do?
C3451 Description Warming-up failure
- The surface temperature of the fusing roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Remedy 1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Jan 12, 2015 | Xerox Office Equipment & Supplies
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Oct 12, 2014 | Konica Minolta 120v Fusing Unit For Bizhub...
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
Feb 14, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Rebooter
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Malware functions eror cod c3451
C3451 is a Warm Up Failure. The fusing unit uses heat a pressure to "fix" the toner onto the paper. This code means that this unit is not heating up properly. You will need a service person to diagnose which part has failed and effect repairs to resolve this code.
Here is the info from the service manual:
The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Dec 02, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Help error c3451
It is the fusing error problem.Check the contact house and wires of the fusing unit and mother unit.
Sep 27, 2009 | Minolta Office Equipment & Supplies
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Minolta bizhub 200 All-In-One Printer Logo
159 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
