Question about Philips 27PT6441 27" TV
Phillips tv problem
Yes I am able to solder.
  • Anonymous Apr 04, 2008
    REPLACED FUSE,SET STILL WON'T COME ON.WAS HEARING CLICKING SOUND BEFORE REPLACING THE FUSE.NOW AM NOT GETTING ANYTHING.
  • 138 Answers
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
Posted on Aug 19, 2008
Hack for loose av jacks
These jacks are directly soldered to its main board. If you want to repair the loose contact, you have to open the TV, and take out the board to look for the loose solder points, and have to re-solder it. Contact any service technician. Gopakumar Gopalan Google
May 11, 2014 | Televison & Video
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a phillips lcd hdtv. When I turn it on the light blinks 6 times. I'm sure its the power supply board, my question is how do i repair the power supply board without replacing it? I have a power...
look ON THE POWER SUPPLY FOR SWOLLEN CAPASITORS. usually 2 RIGHT BY HEAT SINK. VALUE VARIES... REPLACE ANY SWOLLEN CAPASITORS AND SHOULD SOLVE PROBLEM
Feb 17, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Phillips hd tv. model # 46pp9302/17f We lost
It is possible that your tuner module has some dry solder/weak joints that is causing the fault. Open as before and look into the board very carefully to see if there is any weak spot. Use a good solderring iron to touch up all the suspect areas but be very careful and do not try this if not familiar to solder as it might turn serious. Hence you can ask an electronic technician to check on this and solder up the chroma/processing stages and reset. If this does not solve the issue , the fault could be failure of the concerned IC. Confirm and replace carefully. Hope you get this right.Good day
Jul 30, 2010 | Philips TV Tuner Video Capture PCI Card -...
My 60inch phillips hdtv won't turn on and i can
This problems,cause by the 2 STK dead convergence too.U must have soldering tools,solders and must Know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop cost u $300-350 for parts and labors.
May 07, 2010 | Televison & Video
37in model 37pf7320a/37 , wont stay off settings mode
I fixed a Phillips 37" TV that was doing this by re-soldering the wire/pin joints on the button board (side of TV). You have to take the TV apart and have a soldering iron to do this, of course. But it's really not that hard to do.
I'm a caveman, and I did it!
Dec 05, 2009 | Televison & Video
Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Aug 07, 2009 | Philips 52PFL7422D/37 TV
PHILLIPS PROJECTION
Yes just let me know your model number and what parts you are needing as I also work at a site that sells any part you could possibly need for your TV.
Mar 28, 2008 | Televison & Video
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
Philips 27PT6441 27" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
