Question about Yamaha RX-V661 Receiver
Fuzzy sounds quality from receiver
I've got a Yamaha 5.1 surround receiver. I have 2 front speakers, 1 center speakers and a sub-woofer connected. When I watch dvd's, the sound quality is so fuzzy, I can't make out what people are saying.
Any ideas?
  • 61 Answers
Your surrounds are probably set too high and the the center set too low
Posted on Mar 06, 2008
Can I add more speakers to my HT-J5500W Samsung sound system.
The HT-J5500W can only support a 5.1 speaker system. The main part of the entertainment system supports a direct connection with the front right, front left and center speakers and sub-woofer. The wireless receiver module connects the surround right and left speakers to the rest of the system.
You would need a different amplifier/receiver to switch to a 7.1 or other speaker system using more speakers. You may be able to upgrade the individual speakers, as long as you don't exceed the power output limits of the system. The original speakers are 165 W each (front and surround speakers) and 170 W for the center speaker and the sub-woofer.
I hope this helps.
Mar 04, 2018 | Samsung Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Yamaha Surround Sound HRT-6030
Hi!
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Yamaha RX-V661 Receiver Logo
148 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
