Intermitant fault zanussi zwx1506w washine machine
Machine would not spin with one towel in, machine span ok with two towels, tried machine on full cycle again worked ok, next load as far as spin then stopped with no spin, is there an out of balance control on the pcb that causes trouble?
  • 30 Answers
Try these two things first:check the brushes on the motor you will have to remove it first they are held on with two screws on each,and also there is a drain filter behind the kick plate at the bottom of the machine if this is blocked it does sometimes cause the machine not to spin properly hope this helps
Posted on Mar 07, 2008
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
Zwp1121p Spinning but clothes still we5 through
Is the spin cycle reaching full spin speed or is it not spinning as fast as it should? If it isn't reaching full speed it could be caused by an uneven load (as this will stop some machines from spinning properly). Towels and items which get very heavy when wet can cause this.
Oct 27, 2013 | Zanussi Washing Machines
Hi, I have a Zanussi TC482W which is spinning, but not heating up
Either the main heater has burnt out or the thermostat found inside drum housing above door.Also the water tank inside the machine could be full there is normally a small rubber cap with a wire clip on it at rear bottom of machine take this off and drain water onto a towel and gently tip back machine to get all out.The other fault could be the timer.
Hope this helps.
Feb 07, 2010 | Dryers
Whirlpool top load wash machine does not spin
Check your lid switch it may be bad.
Mar 18, 2009 | Washing Machines
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Intermitant fault
Sometimes the Brushes on the motor can cause intermitten rotation. The brushes are the electrical contacts for the motor to rotate. When they wear down or degrade (and need replacing) under spin conditions the motor may fail to turn as it may have hit a dead spot on the motors commutator.
Best course of action is to see if the Brushes need replacing. The cost of new Brushes is < £20. The labour may be vastly more if you pay someone - but it should be done in less the 0.5 hour.
Brushes usually come in pairs (Pack of two).
If your unit is hotpoint I can offer some instruction on how to fit yourself.
Regards
Mar 06, 2008 | Washing Machines
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
