Intermitant fault machine would not spin with one towel in, machine span ok with two towels, tried machine on full cycle again worked ok, next load as far as spin then stopped with no spin, is there an out of balance control on the pcb that causes trouble?
  • sparkyme Mar 08, 2008
    brushes checked ok
  • 108 Answers
Sometimes the Brushes on the motor can cause intermitten rotation. The brushes are the electrical contacts for the motor to rotate. When they wear down or degrade (and need replacing) under spin conditions the motor may fail to turn as it may have hit a dead spot on the motors commutator.
Best course of action is to see if the Brushes need replacing. The cost of new Brushes is < £20. The labour may be vastly more if you pay someone - but it should be done in less the 0.5 hour.
Brushes usually come in pairs (Pack of two).
If your unit is hotpoint I can offer some instruction on how to fit yourself.
Regards
Posted on Mar 06, 2008
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
How to fix drain-spin problem after overloading in wash...?
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
Warranty still valid? try that, Also could be a
"hidden" recall. But the MFG definitely needs to know about these kind of problems.
Apr 13, 2015 | Washing Machines
Machine won't empty
It will not spin if there is water in it.
Locate the filter, which should be at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Hope fully this will solve the problem.
Jan 21, 2010 | Bosch Classixx WFC 2465 Front Load Washer
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Intermitant fault zanussi zwx1506w washine machine
try these two things first:check the brushes on the motor you will have to remove it first they are held on with two screws on each,and also there is a drain filter behind the kick plate at the bottom of the machine if this is blocked it does sometimes cause the machine not to spin properly hope this helps
Mar 06, 2008 | Washing Machines
Washer not fully draining, even with extra drain/spin cycle...
Hi easterbunch;
Im sorry to have to tell you but that is one of the inherant faults of the duet line of machines. It is a safety guard that the machine sences as a unevenly distributed load, and prevents the unit from spinning up to full rpm's The next time you need to do a small load throw a bath towel or two in with it and you wonrt have any problems with it spinning up to full speed.
Hope this helps :-)
Feb 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
