Question about IBM ThinkVision L170 17" LCD Monitor
Monitors video and power blinks on and off
When i plug the monitor in the led terns on green then terns to orange
then terns off for ten seconds when the led is green the video comes on and shuts off again
  • 472 Answers
Yet another case of bad capacitors on the power board.
These monitors are well known for this issue, but they live a long time past when they should.
Easy repair, but if your not confident around electronics drop it to your local TV repair shop.
Hope it helps =)
Posted on Apr 10, 2008
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
When I power on I get a green light on the monitor
Monitor is not geting the signal from the PC.
connected the monitor to the AVG port on the rear of the PC and see if you get the monitor to go up. if not, try to get a video card.
Jan 12, 2009 | HP Compaq d530 PC Desktop
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
380 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
