Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Power outage problems
My computer will not reboot after a power outage. There's a black screen that says "Compaq" and Esc=reboot, f1=yadda yadda, f10=system recovery but nothing happens when I hit these buttons to reboot my computer. What should I do?
  • 492 Answers
Power outages can cause problems. Based upon the symptoms your motherboard or hard drive has been damaged.
Posted on Mar 07, 2008
The screen lights but the desktop never appears. what's wrong?
Try the soft reset. By removing the battery and power plug. Press the ESC or F1 key for 10 seconds without removing your finger to the ESC or F1 plug the power back in. Then when it powers up remove your finger to the ESC or F1 key. This will reset your laptop and check the hardware problems.
Mar 09, 2011 | Toshiba Satellite M45-S2692 Notebook
On the bottom, it shows <esc=boot menu> <f1=setup> <f10=system recovery> but it doesn't respond to anything or move from this screen
Check that your keyboard is connected, and is working properly.
Try your keyboard on a different computer.
Try a different keyboard on your computer.
The 'ESC' key should always work.
The 'F1' key should always work.
If your disk-drive is *NOT* "dead", then the 'F10' key should work.
If neither 'ESC' nor 'F1' work, you have a serious problem with the motherboard.
Feb 03, 2011 | HP Compaq Presario SR1850NX (ER925AA) PC...
Cannot boot up normally the screen stays dark, but clicking esc when powering up and continuing with f1 does work. why?
Sounds as though your drive boot setup isn't right check in BIOS. F1 is the classic "Continue" after problem encounter key. The Esc, allow you to override and continue.
Feb 05, 2010 | HP Compaq Presario 2200 Notebook
Black screen upon start up
Remove the battery for 12 min, then power up your computer with your power cable only, then press ESC rapidly , if not, press F2 rapidly.
your computer will start up, i suggest that you remove your graphics card driver and use another more compatible one, because this is the problem!
Jan 31, 2010 | Compaq Presario 700 470024-192 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
I have the same problem with my Compaq. Its frozen on the logo
hi there..
turn of your computer..
unplug all the cables...
press and hold down the power key which is on your cpu for atleast 5 - 10 secs..
after that ..please connect the power cable.. mouse.. key board. monitor and your internet cable..
and then restart your computer..
when you restart your computer keep tapping the f1 key (i hope this is for bios)..
restore to default over there.. press enter to save.. once done this would automatically reboot..
this should fix this problem...
please post your answers.. or comments...
Aug 20, 2009 | Compaq Computers & Internet
I have set up my compaq computer , it was working fine, then I shut it down. Now when I start it up it goes into the compaq screen asking for press esc or f11 or f10 etc for rebooting etc. What have I...
The Start up screen for Compaq series computers is normal, that screen takes you into your BIOS mode. when the screen appears press F1, at the bottom of the screen it will say press F5 or one of those keys to install your Default Settings, Click Yes and Exit. That should do it. Good Luck.
Oct 28, 2008 | HP Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
1801 Microcode Patch Error
I bought a Compaq Computer, 2.0Ghz, 256MB, 20GB for my College project. When i put the power on, it restarts almost immediately (so many times repeatedly). Then after such reboots, it successfully brings a message "1801 - Microcode Patch Error" and a F1-Boot directive.
Mar 20, 2008 | Compaq Evo D500 PC Desktop
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
226 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
