Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Daewoo IRT20A5T Tv comes on and off without stabilizing
When the tv is powered, the power recycles between on and off without stabilizing. I suspected the flyback transformer because it is producing a spark ,but changing it does not solve the problem.I have traced for any posssible short cct,but have not seen any.Please i need a solution!
  • 2,322 Answers
It looks like the spark you hear is comming from one of the high voltage anode connection on one of the CTRs, It could be leaking coolant fluid or just have some moisture around it.
Posted on Mar 06, 2008
Ln52a550p3fxza wont start cycles on and off
The problem could be temperature related. I replaced both my processor board as well as the power supply board and the problem is still there BUT I found a VERY simple solution that just requires me to keep the TV on all the time. When the TV is at room temperature, it literally takes 10-15 minutes for the system to stabilize and provide a good picture and audio. When my basement was at 55° for a few days, it took over 1 hr for the TV to stabilize. I now switch the input to my Roku player input and leave the TV on all the time. The Roku screensaver kicks in and all is fine with the world. No more issues with the TV not working. It adds to my electric bill but it is cheaper than replacing another board. When the TV dies, I'll get a replacement TV.
Dec 08, 2015 | Samsung LN52A550 LCD TV
How to pix daewoo 21" FLAT PANEL TV NO POWER
Here's how to pix it: Usually a fuse is on the power supply module inside the tv. You'll have to replace the module.
May 13, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
DAEWOO TV
If youe tech inclined you can open the unit and see if the fuse is blown if you are uncomfertable on doing that then your going to need to take it into a repair shop.
Apr 21, 2009 | Daewoo DTQ-27S5FC 27" TV
TV DOES NOT COME ON VIA POWER OR REMOTE
The problem  may be limited to a blown fuse which may not be accessible from outside the set. Removing the back cover isn't normally a tough job and any fuse would be close to where the power comes in. I recommend pulling the AC plug overnight since there are components inside that can retain dangerous charges for hours. If it  is not defective (if clear glass, a flashlight will help seeing it), then the failure is probably in the power supply and this may require a professional to troubleshoot.
If you own a multimeter and want to try to locate the failure, post back to this thread and I will give you some guidance.
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo cp185
Power supply may be faulty.
Initially check fuse in power line input.may be burned.
Jan 23, 2008 | Televison & Video
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
