Question about Olympus Camedia P-10 Thermal Photo Printer
Ribbon jamming in printer
I have 2 P-10 printers purchased at the same time and at about the same time, they both started having ribbon jamming issues.
Recently, I purchased 4 100 shhet packs 4x from B&H Photo for a job. On the 4th print through, the printers jammed up and the ribbon was wrapped around a roller. I have to cut the ribbon and carefully pull that ribbon from around the roller off. Now on my 4th attempt and $160 later, it still was happening. Now I have 4 busted ribbon cartridges and 300 sheets of unused paper.
I sent the printers back to Olympus and they told me that it was the motherboard. It would cost me $110 a piece to bring them back to factory condition.
I found 2 new unused P-10's on Ebay for $40 each.
Where can I find motherboards for these printers so I can replace them myself?
And by the way, I had a tough time getting Olympus to refund me the loss of materials but they did send me 3 out of the 4 boxes in good faith.
  • 30 Answers
I will simply advice you to pick another printer instead of the mother board because it might not be the only problem your printer has
Posted on May 18, 2009
  • victor obike Nwabuisi May 18, 2009
    i will simply advice you to pick another printer instead of the mother board because it might not be the only problem your printer has
Error ribbon jam
Insert the ribbon in the printer, as you would normally. Go to your "devices and drivers" or "printers and faxs" in you start menu. Right click the DTC 550 and select printing preferences.
With the Ribbon installed, printer head lowered, and the top closed. Click the "Device Options" tab. On this screen you will see a button, towards the top, "Auto Ribbon select". Click this, and you will be prompted with a "Ribbon select success".
Now click the "Calibrate" tab at the top of the window. Select "Sensors". Another window will appear. Under Ribbon calibration, click send.
If the problem persists, you may have to update your printers firmware.
Apr 11, 2014 | Fargo DTC550 Thermal Card Printer
Ribbon jam
Try replacing with another ribbon
Mar 30, 2014 | Epson DFX-9000 Matrix Printer
Shows no ribbon
When the unit shows No TFR Ribbon in the screen this usually means the spool has come to an end and its time to install a new ribbon set. If you know there is ribbon installed and you are still getting this message it means the sensor has been misaligned and is not reading correctly or the transfer film is jammed or broken. First check the ribbon is neatly wound up on the spool and is not torn then reinstall and check again. If it still shows no tfr you need to have the unit serviced. Never force the cartridges at any time while installing or fixing a jammed spool as this will sometimes move the settings on the sensors.
Feb 15, 2013 | Teac P-55 Thermal Printer
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Epson printer dfx9000 problem ribbon jam errorr i change the ribbon cartridge and test in another printer my ribbon is correct but in this printer this error is shown yet what should i do?
Check for any foreign objects that could be affecting the ribbon cartridge assy ,clean and reset ,perform a maintenance check via the printer menu
Feb 03, 2011 | Epson DFX-9000 Matrix Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Ribbon jam
i get the error RIBBON JAM anytime i try to print,even though i have changed the ribbon.Dan
Sep 11, 2008 | Epson DFX-9000 Matrix Printer
Olympus Camedia P-10 Thermal Photo Printer Logo
64 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
