Phones
Problem for Phones
Generic problem for all Phones
Resetting a Bell+Howell Secure Pro Key...
By jesseRatt on Mar 06, 2008
I recently purchased a condo that had a Bell+Howell Secure Pro Keypad Alarm system installed. However the owner did not leave me any manuals or key codes for setting it. Right now its disabled but I would like to start using it. How can I reset it and put in my own codes, is there instruction manuals available some where.
The product does not have any sort of product number or identifying model information on it but i did find an image of it here:
http://ecx.images-amazon.com/images/I/413KRYYEE8L._AA280_.jpg
Please help!
Comments:
Mar 06, 2008
- Please email me a resposne at jratterree@sbcglobal.net.
Same Problem
Nov 19, 2008
-   I bought this alarm new, took it out of the package, didn't have a nail, so set aside til later and what do you know? My husband threw out the package. I have tried everything to reset it as it has never been set before. All I ended being able to do is take out the batteries. I have exhausted all of my options. If anyone could help, please let me know @ sweetmamajohnson@verizon.net. Thank you in advance as me and the kids will feel safer when we are home alone. Della~ -   sweetmamajoh
Apr 07, 2008
-   Good morning, I bought this product and I can not make it work, in the package there are no instructions and only the panic button works! -
Buon Giorno, anche io ho comprato questo prodotto e non riesco a farlo funzionare, nella confezione non ci sono le istruzioni e solo il tasto panic funziona!!!-   Zandan
Mar 30, 2008
-   I need the instalation guide too..
Carlos
carlos@grupofabrega.com-   cfabrega
Best Solution
posted on May 16, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yes many thanks for your suggest!!
Solution #2
posted on Jul 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yo no consigo que funcione
Solution #3
posted on May 13, 2008
Helpful)
hopeit2008
Rank: Apprentice
Rating: 85%, 4 votes
We had ours all set up and threw out the manual. When the batteries died then it went back to the manufactures setting. We punched in 4 zeroes and pressed code. Then we put in our new 4 digit code and reset it that way. Hope it helps.
Was this helpful?
Yes
No
Solution #4
posted on Aug 08, 2008
Very Helpful)
mccoy88f
Rank: Apprentice
Rating: 100%, 1 votes
Per tutti gli italiani...
Staccate la batterria
riattaccatele.
Ora premete 4 volte zero
e poi code
ora inserite il nuovo codice a 4 cifre inseritelo e ripremete code.
Ora se volete inserire o disinserire l'allarme
inserite il codice da voi scelto e premete on/off.
Ciao ragazzi
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jan 07, 2009
Not Rated)
juanojeda200
Rank: Apprentice
Rating: 0%, 0 votes
thanks the info was great
Was this helpful?
Yes
No
Solution #6
posted on Dec 27, 2008
Not Rated)
jamie61
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and solution 3 by hopeit worked for us. You just type in the four zeroes and push code. Then you put in your new code and push code again and the system took it. Thanks hopeit.
Was this helpful?
Yes
No
Solution #7
posted on Oct 14, 2008
Not Rated)
zakhiyya
Rank: Apprentice
Rating: 0%, 0 votes
HEY!
when we enable the alarm, how do we disalarm it when it goes off?
Was this helpful?
Yes
No
Solution #8
posted on Oct 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
quita las pilas y ponlas otra vez
pulsa 4 ceros, y pulsa code
inserta los 4 numeros nuevos del codigo nuevo, y pulsa code
enciende la alarma o apagala
inserta el nuevo codigo y aprieta alarma
por benjamin sin verlero
Solution #9
posted on Aug 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have also purchased the same model and it did not include the alarm, the solution posted by hopeit2008 did not work unfortunatly, anyone got any other solutions? would be very grateful if they did.
t
Solution #10
posted on Jun 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ho lo stesso problema cavolo
Popular Solutions for Phones
Questions and Unsolved Problems for Phones
Answer
Need a unlimited phone book memory phone in CDMA
Answer
White backlit LCD on handset stopped displaying info,screen is blank,I changed the battery,still... (More)
Answer
samsung f480 have to charge nearly everyday, why?
Answer
i have a mobile phone nokia 6233 it have a memory card but it have been password lockedhow can i... (More)
Answer
My phone says "PLACE HANDSET ON MAIN BASE TO REGISTER" & it wont do anything else.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phones Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
