Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
