Question about Motorola Mobility RAZR V3
Phone keeps resetting
When I turn phone on and by the time the wallpaper displays, it resets and powering up again.
  • 492 Answers
Sounds like a flash problem with the phones os. You will need to contact your carrier for further assistance.
Posted on Mar 07, 2008
What can we do to unlock my wife's kyocera phone?
This option is actually a last resort if you are unable to recover or remember the code you have set up..
Hard Reset the phone which will erase/delete all data stored on the phone.. if you can somehow access your data via a computer, try to backup your data before doing the reset. If the phone has a memory card added, you can remove it before the reset process.
Ways to hard reset the phone.
Turn off the phone. If by any reason you cannot turn it off using the power button, remove the battery. Open the flip once the back of the phone has been exposed. Look for the "Reset" button using a small pointed object. Keep pressing it then press the "Backlight" button located on top of the phone.Release the "Reset" button after approximately 3 seconds. Release the "Backlight" button when the display on your phone appears.Choose the "Yes" option by pressing the "Up" button when the "Erase all data?" message appears. You must select the "Yes" option to complete the hard reset.
Another method is to again make sure the phone is turned off. Then press and hold the Volume Down button/key at the same time, press the Power switch/button until the phone starts and display comes up. Release the keys then use the Volume up/down button to select "wipe data/factory reset" then press the Power key. Choose "Yes -- delete all user data" then press Power key again. Once done, do the same steps to perform "wipe cache partition ". Once completed, let it reboot and set up your phone again.
Hope the info sheds some light of hope to at least allow you use your phone again, though as if it is the first time.
Aug 09, 2014 | Kyocera Cell Phones
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
I have a canon pixma 160 printer where it continually says "no ink" for both colour & black ink with either new original and or new compatible cartridges. the printer keeps showing 5...
Folow this procedure, let me know if there are any questions.
1. Turn off the printer (but make sure power cable is plugged in wall outlet).
2. Press and hold down the Stop/Reset button
3. While holding the Stop/Reset button, press and hold down Power button.
4. While holding down the Power button, release the Stop/Reset button.
5. While still holding the Power button, press the Stop/Reset button twice.
6. Now release the Power button.. (wait until it display "service mode")
7. Press the Stop/Reset button (4 times to clear waste ink; 8times to reset ink level)
8. Turn off the printer
When you turn on the printer, it will work again.
Jan 15, 2011 | Computers & Internet
Iphone wallpaper got change from unauthorised person showing it doesnt do anything yet but it /did/ get loaded off the server :P (awesome, huh)
While there are some security exploits for unlocked/unrestricted phones, I have not heard of a standard locked iPhone being hacked or accessed remotely. I have seen however cases where a wallpaper or icon resets to a previous or apparently "random" (nothing is actually random, but at least unexplained) image following an application crash.
Often doing a hard reset on the phone fixes it.
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
  6. You have completed a hard reset successfully.
Mar 19, 2010 | Apple iPhone 3G
EnV Touch Keeps resetting
I have VX11KV03 and I am having exactly the same issues; phone reseting to default display, sound, etc and trouble charging. Verizon tech support suggest a *211 call to update the software. Also, with the charging, even though this is still a hassel, unplug and replug in your phone after it says charge is complete. It will actually fill the charge the second time. Hopefully this wroks!
Oct 09, 2009 | LG enV VX9900 Cellular Phone
Background keeps changing everytime i shake my cect i9 phonee
hey yes you can diable the shake feature on both the wallpaper and the music player
1. go to settings
2. hit phone setup
3.on the next menu go allll the way down to the bottom and you will see Gsensor swich wallpaper
and gesensor switch song. trust me its there u just gotta keep scrolling.
4. click off on them both and you have it.
hope this hepls, cuz hat shake is annoying
Dec 31, 2008 | Dual Electronics CECT P168 Cellular Phone
Won't accept key input
There might be a problem in ur.....key pad. Did u tried to install the previous battery.......again.....
Jul 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Nokia so annoying please need help
if u will remove ur memory card the problem will always rise u must simply copy ur wallpaper, ur ringtone, ur themes to phone memory and then remove memory card then set ur wallpaper, ur ringtone, ur theme. switch it of then insert memory card and then turn it on u will find that they are not reseted again. and please rate this solution. Have a good day
Apr 22, 2008 | Nokia 6288 Cellular Phone
Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Oct 08, 2007 | HTC P3300 Smartphone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
