Question about Panasonic KX-FHD351 Plain Paper Thermal transfer Fax
Panasonic kx-fp 342 papaer jam
Sir
when fax came or making xerox, while half the paper inside, papaer jamed and display shows paper jamed.i cleaned rollers with alchohol but no use,please let me know any other remedy
  • Ikokoto Investment Dec 31, 2012
    I have panasonic kx-fx 342 it receive and send fax but the problem is when it receiveor send if is one page when it finish is take next page without commanding and is going a half and jam. Then message Paper jam come out
  • 682 Answers
Paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Posted on Mar 07, 2008
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Our fax machine - panasonic model fp-342 can't received fax due to error display "fax memory full" . How can i fix that?
This fax machine stores the faxes in memory and then prints them out.
If it's unable to print them, is either because there is no paper or no ink.
The memory eventually gets full and stops receiving faxes.
Apr 01, 2011 | Office Equipment & Supplies
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Panasonic fax kx-fp153
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
I need plain paper fax panasonic kx-fp 200 immediately
The refills that fix the kx-fp135 will also fit your model kx fp 200. Office Depot has this and it can be ordered onlin. : http://www.officedepot.com/a/products/288514/Panasonic-KX-FA136-Black-Imaging-Film/
Apr 16, 2009 | Panasonic KX-FB421 Plain Paper Film Fax
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Dec 29, 2007 | Office Equipment & Supplies
Panasonic KX-FHD351 Plain Paper Thermal transfer Fax Logo
281 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
