Faulty goodmans 1104s dab player
Goodmans micro 1104s dab: inserting cd into player and closing lid, display reads 'no disc', with lid open and lid interlock overridden - same display info. with the slightest of finger pressure on disc surface and reactuating lid interlock disc is read and displays track info. then pressing play without touching disc cd fails to play track 1, but with minimum pressure on disc, pressing play, cd will play 1st track. in addition if the magnet from inside the lid is removed and placed on the disc (with the lid still open) fault still occurs. Q: why and can it be fixed??
  • pharris50 Mar 09, 2008
    thanks for reply, had tried your suggestion. dismantled assy down to laser head no abvious fault. pressure on disc spindle rather than disc also overcomes problem, wonder if laser/disc distance is critical? have now placed material inside lid behind screw which holds magnet in place increasing pressure onto disc when lid is closed unit now appears to work 90% of time - not a good fix, but seems to work for now !!
I had this problem and cleaning the lens with meths and a cotton bud completely fixed it on a Goodmans MICRO1104SDAB. Matt
Posted on Sep 06, 2012
    Master:
  • 518 Answers
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Posted on Mar 06, 2008
My CD tray closes before I insert disk
check the micro switches on the cd mechanism. these can go wrong sometimes. it's obviously not sending a message to the micro chip that the tray is open therefor it will close again automatically.
hope this helps?
May 10, 2010 | Arcam Alpha 7SE
Cd player drawer will not stay engaged when a disc is inserted
By not engaged i'm assuming you mean that the disc draw closes then opens again almost immediatley. This would indicate that the disc draw limit switch is not being activated by the draw or the switch has failed.
This is usualy a small sub-miniature micro switch activated by the draw itself, Sometimes a very light spray of switch cleaner into the micro switch will effect a cure. The switch gets a fairly hard life so it is more advisable to replace the switch.
Mar 16, 2010 | Sony Audio Players & Recorders
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
When I close the lid on the portable DVD player it says that it is open and wont read the disk, can you help
The lid closure interlock is not satisfied; it's located to the left of the open button (a tab on the top lid should hit the switch when closed)
Feb 21, 2009 | Coby TF-DVD7100 Portable DVD Player
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
CD player not turning
the tray should have a micro switch to touch when its closed. maybe it needs some fine adjustment. if it doesnt say closed then the laser drive wont start. or maybe the magnetic clamp hasnt come down onto the disc properly
Nov 09, 2017 | Audio Players & Recorders
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Televison & Video Logo
385 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
