Question about Arris DSR922
Will not set limits (changed arm)east & west or same spot how to breck free
Changed arm on dish and now it will not move the east & west or in same place and cannot go in eather direction!
  • oldman848 Mar 09, 2008
    Thank you for the comment,it helped to fix my bigdish and now i can watch tv again. thank you Jerry
    Master:
  • 518 Answers
I assume this is a larger Satellite Dish with a motorized arm to move it from sat to sat.
There's 3 things that can cause this:
1. Limit switches in the back of the motor are not aligned properly.
2. No power to the motor on the 2 larger power wires. Bad wiring, bad box in house, blown fuse.
3. Magnetic pulse switch in arm not sending pulses to box. Bad sensor, or bad wiring. In this case the motor would move a bit then stop.
Hope that helps
Geno
Posted on Mar 06, 2008
Hi, the dishes on the top rack of our Whirlpool Quietmaster III do not dry completely, but the bottom dishes are fine. We have to re-wash the upper rack dishes; they have spots on them. Ron.
Make sure the top spray arm is turning! check for blockage in the jets at the very end of the spray arm, or that the spray arm has not split. Put the arm in a known position, and check it has moved after a few moments. Remove blockages or replace the arm if necessary.
These machines dry only by the last rinse being in hot water, then the plates drip dry. Are you using rinse aid? this helps the water to disperse without spots.
Jan 30, 2018 | Whirlpool Dishwashers
Changing sattelites
check this site
http://www.criscros.net/4dtv_setup_guides.htm
and
http://www.criscros.net/4dhelp.html
Apr 23, 2008 | Arris DSR922
Just got my husband a casio pro trek sgw100-1 - we calibrated the compass but east and west are switched - north and south are fine - any ideas? thx
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
Nov 29, 2010 | Casio Watches
I changed the Navigation disc to west side and can't get it to accept the east side navigation Disc? Is it possible? How?
eject the disc and reset the radio. then try to insert the east coast disc again. should work again after reset
Feb 06, 2010 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
Food particles and spots on dishes
Are the holes in the spray arms clogged? That will cause it and they're not too hard to clean out.
Dec 12, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Problem in SGH X620, NO imei, Limited service
problem in sgh x620 ,no imei ,limited service
Jul 02, 2009 | Samsung SGH-G600 Cellular Phone
Dishwasher runs but does not get dishes clean
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
Apr 08, 2009 | KitchenAid 24 in. KUDP01IL Stainless Steel...
My goodmans TV has changed it's picture to a goldfish bowl effect. It has not got widescreen settings as it is over 10 years old. I have tried turning the set off and on but it has not changed it? Any...
This sounds like what is referred to as an East-West fault. This is caused by initaillly a poor solder connection, but then can cause a capacitor, a diode and occassionally the E-W transistor to fail. You will need to take it to a repair centre.
Mar 28, 2009 | Goodmans Televison & Video
Have a DSR 922 that I can not get W5 to program in the satellite list. When I highlight it and push enter it all ways returns to the current satellite I was on, insted of letting me move the dish to the W5...
Do not know if I solved the problem yet. Went on Skyvision site and somebody had the same problem. They told him he would have to do a Master reset, and reprogram all satellites and east/west limits. Just haven't had time to do this yet. Will let you know if it works.
Mar 06, 2009 | Arris DSR922
GE Triton XL Dishwasher
Make sure wash arms are going around. Set the arms to point right at you and mark with a marker (so you can tell if the arms moved, not just turned 180 degrees) and run the unit for a few seconds. If the spray arms don't move, look for obstucted holes in the spray arm(s). Toothpicks, plastic candy wrapers, seeds, etc. If all clear, so an "Ask Me" for other ideas.
Sep 02, 2008 | Dishwashers
Televison & Video Logo
182 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
