Question about Western Digital External USB 2.0 80 GB Hard Drive
WD USB 2.0 External HD Power Issue
Sorry for my tech ignorance with this. My 120gb WD external HD was working fine one day, the next it wasn't. The blue power light comes on for a second then immediately goes out. It doesn't sound like it's powering up at all. With it having a blue light at all I'm assuming that the power cord works.
Any suggestions what it could be and how to fix it? I've read where sometimes you can remove the drive from the enclosure and either install it into my PC or put it into another enclosure. Is that an option?
Thanks for any help! As you might expect, it happens when a deadline is looming!!!
  • 1 more comment
  • jcuhaj Mar 06, 2008
    Thanks. This is what I needed to know. I appreciate the answers!
  • zanne80 Dec 30, 2008
    My blue light goes on, blinks and then goes off. What can I do?
  • 61 Answers
Yes you can remove it from the enclosure take the HD out and connect it as a slave on your computer and see if it works
Posted on Mar 06, 2008
  • 133 Answers
Yes removing it and installing it inside the pc is a good option and thats the only way for now you can know whether its the harddisk itself which is damaged or the external casing hub. if u connect it in the pc set it as slave, or secondary master, since u need the one in the pc bcoz it has the operating system
  • 75 Answers
Not by you ,technition can do
My Pleomax external hard drive stopped working on my MacBook (OS Maverick). It worked for one day and that was it. It flashes green and red when connected.
Probably not an issue with the MacBook but with the Pleomax drive. Be sure the drive is getting enough power to begin with. If it came with a 2 headed USB cable be sure to connect BOTH USB connectors to the Mac. You may also want to try the drive while your COMPUTER is plugged in and charging. Laptops and external drives don't always get along due to power differences and specifically laptops who do not want to waste their battery power on an external drive. If all else fails, try the drive on another computer just to make sure it is a drive problem and then contact the manufacturer for a repalcement drive.
Dec 11, 2013 | Samsung Pleomax 120GB External - USB 2.0,...
I have an USB External hard drive 70 gig from I/O Magic. It was working and one day I turned off my computer and when I went to boot back up it wasn't showing on my system, What can I do?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 29, 2011 | Magic I/O MAGIC CORP 120GB IDE PRTBL HD...
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
My usb ports are limited to 500mA each one and the WD external HD needs at least 1000mA. How can I solve that?
You might need to install a new USB card, one with 1000 mA, to provide the power necesary for your WD external drive. Check the WD manual to see whether there is a way to use two USB ports when jumpering them to see if you can provide the power yourself.
Also check the WD web site.
Jun 26, 2009 | Western Digital Passport 120GB External...
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Western Digital External USB 2.0 80 GB Hard Drive Logo
83 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
