Question about E-Machines eMachines Desktop PC
MY COMPUTER IS NOT COMING UP
AFTER POWER OUTAGE, MY COMPUTER IS NOT COMING UP BUT THE POWER SUPPLY IS WORKING SINCE THE FAN IS BLOWING
  • msjdixon1 Mar 02, 2009
    after comming home from out of town I turned my computer on and it would not leave the desktop. I turned it off and now it will not come back on. Joyce
  • 133 Answers
You need to open it, disconnet one item then switch it on, if it dosn't work, replace it back and disconned another one, do that untill u get to know which one is not working.
Posted on Mar 06, 2008
My computer is coming up no support how will i fix it
Posted on Mar 26, 2009
Booting up computer after a power outage
did you check the power supply if it is working?.look for the exhaust fan if it is rotating. then look at the mother board if the fan at the processor is also rotating if not check the supply first at the PSU if ok.
Jun 05, 2012 | Lenovo Computers & Internet
Hi there,pls help I have problem with this. Power not come at all..it was working fine till the we had a power outage then while the computer was on then the outage went back on my monitor just didnt work...
Hello derick, Unfortunately power surges have been known to have some pretty nasty effects on your computer hardware. If you turn on your power (may have to toggle the power button behind your computer before pressing the button, worth trying in each position just in case) and your computer doesn't come on at all. This means that if none of your lights come on AND none of your fans come on, then your power supply may have blown out in the surge. If this is the case then you can't even begin to try and diagnose the rest of your PC to see if it's working. You need power to attempt diagnostics on your other components. Even if you replace the power supply, there is no guarantee that it was the only thing that was ruined by the surge. I hope this helps you out derick, and wish you better luck in the future :(
May 15, 2011 | Computers & Internet
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
A/c unit not working
So only fan is running, the compressor not running okay check the voltage going to the compressor. The connection is coming from Thermostat or temperature controller, if there is supply going to A/c Comp. check the safety thermostat relay above the compressor.
Jun 01, 2009 | Heating & Cooling
Pc sht down stating thermal error. suppose processr fan not working. can this be the cause of the eror?
Most of the time you'll never hear the CPU fan. If you don't hear the normal fan sounds coming from your computer, it is most likely the power supply cooling fan. Hold you hand at the back of the computer where the power chord plugs in, while the computer is running, and test if you feel air blowing on your hand. If you don't, then replace your power supply. Make sure, when checking for a new PS that you get the correct pin count. Best to order from Dell since proprietary systems usually use proprietary parts and a generic PS won't fit in the opening at the back of the computer (alignment of the plug and the fan with the opening, etc.)
May 25, 2009 | Dell Dimension 4600 PC Desktop
Flashing Green Light on Power BESTEC Power Supply
Hi. NO, *********** board is not fried. I am not sure what the problem is but I do know how to fix it. It is usually casued by power outages (even if you have UPS supply).
1. TAKE OUT THE ELECTRICITY LEAD TO THE COMPUTER. Look inside the computer and find the bunch of wires coming from the power supply unit (the box thing at the top with the fan and all those colouted wires!).
2. Find where these wires run into a plastic connector and plug into the mother board. Unplug it.
3. Now plug the electicity lead back into the computer. The light should now stay ON.
4. Plug in the connector again... and boot up. Leave it run a while to convince it!
5. Repeat this process if it does not work first time.
This should fix your problem . It works for me when I get this problem.
Friend in Spain
Jan 10, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Computer won't turn on
pull the battery out of you motherboard it will reset your bios leave the battery out for a couple minutes then when you put it back in boot up and it should go into bios use your arrows to select set defaults hit enter then reboot it should boot up then if not its possible you have a hard drive issue.
Jan 03, 2008 | Gateway 506GR PC Desktop
Loud fan and wont turn on
power supply is probably shot and you are feeding a voltage way over what is needed. I have a dell that refused to operate one day. I went to www dot affordablesurplus dot com and found a 350 watt power supply with all the RIGHT plugs. Never had a problem since.
Dec 04, 2007 | Dell Dimension 8400 power supply ** FREE...
E-Machines eMachines Desktop PC Logo
125 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
