Question about Phonic MAX 2500 Amplifier
Phonic Max2500 Can't turn my amp on, in 2 seconds it shuts down what may be the problem? Its not the internal fuse and i didnt try the max of the amp.... Thanks and sorry my english
  • rogerxaxis Mar 10, 2008
    Yes with the speakers disconnected or connected... I don't know what to do...
    Thanks
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hey Roger
    Does this happen with the speakers disconnected?
    regards
    Graeme
  • 1,512 Answers
Hi Roger...This amp has a circuit that protects it a number of ways: short circuit, thermal, subsonic, RF protection, and output DC offset. Unfortunately, the symptoms you have, with speakers disconnected indicate that the amp has a failed output stage producing a DC offset, and the protection circuit is operating to protect you speakers from damage. If the amp is still under warranty to Phonic. go here if you are unsure about your warranty, and log a fault with Phonic(I am assuming you are in the US of A)
Other than that, I am afraid you will need to take it to a Phonic agent for repair, as voltages and circuitry used in the model are not suitable for unqualified personnel to repair. Good luck Thanks for using FixYa
regards
Graeme
Posted on Mar 11, 2008
  • 682 Answers
You have real problem in safety contol circuit which shut down the unit to protect the amplifier from damage
Posted on Mar 10, 2008
Why is my speaker not working to full capacity
Hello, First, check the bridge switch located on the rear of the amplifier, should be on STEREO position, GROUND switch to GROUNDED position, check front potentiometer for dirt or scratchy sound as turned it up or down, if none of this solve your issue then could be an internal defective speaker output relay, or channel fuses, let me know if you need further assistance, Regards.
May 10, 2014 | Phonic MAX 2500 Amplifier
The deal is that when my amp stay along like fot whole night without working and then i turn on the amp at the morning i hear cracks and pops on the channel(1).Now the channel (2) stays off until it just...
It sounds like you have "thermally intermittant solder joints" on your circuit board...you may have to remove the circuit board itself and check for broken solder joints around each of the components inside where heat and vibration more than likely has broken the solder holding the components to the circuit board...it could only be one bad joint...but it can become a search and solder type of process so it's just as well to touch up each solder joint individually to make sure they are making proper contact.
Nov 10, 2013 | Phonic MAX 2500 Amplifier
No volume from turntable, even with volume turned to max, are ther internal fuses ?
You don't state which model the turntable is. Without this we are working blind. If the turntable has a built in amp then that will have failed. A blown fuse would shut down everything. If it has no built in amp and you have it connected to a separate amp, then you have either connected it to the wrong socket - it needs a phono socket - or if the amp doesn't have one you need a magnetic cartridge preamp.
Apr 12, 2013 | Audio Players & Recorders
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
I want to connect Max 2500 with 6 JBL Control 28 speakers 175 watts @ 8 ohms each... please suggest what will be the best connection...series or parallel
first is how u want to run the amp itself ....... the MAX2500 can run in mono (bridged) output or stereo ......... though wat u want to watch is the impedance of the load really with the bridged load being no lower than 8 ohms/1500W (there's reasons for this) and the stereo load where u can have either 4 ohms/750W or 8 ohms/500W so how do u want to run this is first the question ..... all 6 on the bridged output or 2 off each channel (though running 3 would make for complicated impedance load) ..... so u'd run 2 in parallel for a 4 ohm load with 300 watt requirement from the amp and u can drive them to 1.5 times their rated RMS figure so a nice 500 watts :)
Feb 07, 2012 | Phonic MAX 2500 Amplifier
I have two phonic 2500 amp, whats the correct way to hook up the crossover
first is how u want to run everything and a bit more about wat u have to go with the rest of the gear would help us answer u better
Dec 06, 2011 | Phonic MAX 2500 Amplifier
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
Hello, i need phonic max 2500 plus diagram
  • 860/1500/2500 MAX 860/1500/2500
    archive.espec.ws/.../PHONIC%20MAX-%20860%201...
    Traduire cette page Phonic reserves the right to improve or alter any information supplied within ... MAX860/1500/2500 SERVICE MANUAL ..... HEAT SINK MAX SERIES PHONIC.
  • PHONIC max 2500 - Service Manual free download ...
    www.eserviceinfo.com/index.php?...PHONIC+max+2...
    Traduire cette page 15 janv. 2009 - Search results for: PHONIC max 2500 (found: 50 regularSearch) ... Audio, 2891 kB, 2178, Service Manual, PHONIC max 2500, VASILICH500.
  • Amplifiers :: Analog :: MAX 2500 Plus - Phonic ...
    www.phonic.com > Home > Amplifiers > Analog
    Traduire cette page Phonic's MAX 2500 Plus Power Amplifier provides 1500 Watts of power at 8 ohms (bridge mono) or 750 ... MAX 2500 Plus Simplified Chinese User's Manual.
  • PHONIC MAX 860 1500 2500 Service Manual free ...
    elektrotanya.com/phonic_max...2500.../download.ht...
    Traduire cette page PHONIC MAX 860 1500 2500. Sponsored link. Type: (PDF), Size 2.9 MB, Page 27, Category: AUDIO - SERVICE MANUAL. Warning! If you are not fa
  • Nov 19, 2010 | Phonic MAX 2500 Amplifier
    Phonic Max 2500 blocked/protected
    the problem of shuting down of amp. is some of output driver are shorted or open check the output driver and predriver
    Mar 11, 2008 | Phonic MAX 2500 Amplifier
    Phonic MAX 2500 Amplifier Logo
    450 people viewed this question
    Top Phonic Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    tom8341
    Level 1 Expert
    Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
