Lots of problems
I have a problem with my HDD am dvd-rom, when i try to enter the hdd the OPEN WITH window apear and tells me to choose a program, and when i open the dvd-rom the search window apear. pls help me guys i ve tryed to format and the problem is the same. ty for ur help
  • 133 Answers
That problem is caused by viruses and nothing else, so clean your machine, but in the time being u can access the harddrive and cd by opening it from the address bar.
Posted on Mar 06, 2008
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
I have an error code HDD ERR
When your HDD (Hard Disk Drive) does not work, the computer would like a recovery disk, or with windows the Windows disk will do. If only the OS has some damage windows will see so and ask, should I recover the OS already on the HDD. If you choose that opting, the CD will try to recover everything.
If your HDD is really defect and can't be recovered by the OS, toy have to replace the drive and setup the computer again. You have lost all data and all program m's on the HDD, so I hope you have a backup of at least all your data.
Good luck
Jul 21, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
My dell inspiron 5620 wont go further a black error recovery screen
Shut down, unplug, remove battery, plug in, reboot, Try a system restore/recovery. If that fails, place a repair desk in the DVD/CD rom and reboot from DVD/CD rom, try a repair my computer first. Your MBR is missing or your HDD needs replacing. Is the HDD LED blinking at start of machine? Open the machine and reseat the HDD and memory mods. If that fails, remove HDD and test, replace if necessary. You didn't mention your OS? Windows XP? This may help:
Dec 17, 2012 | Dell Inspiron 1200 Notebook
Not detecting cd drive, boot device. I have tried cd drive that i know it works in other server. I have installed new hdd and want to load os. It shows specs of hdd but wont detect hdd or cd.
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 01, 2011 | Intel SR1400 (SR1400NA) Rack-Mountable...
I changed hard drives and now I can't load my programs back on
ok thanks for you prompt reply.
when you say laptop not reading HDD it allows you to see dell logo but after that there should be a msg an error msg saying no boot device been found..or just a black screen?
check BIOS if hdd is detected. if yes then it means windows is problem probably but we need to double check on this. run diags on the hdd alone use the dell diags disc. check if you get erorr code. running the diags is like this. keep tapping on F12 after seeing dell logo then insert disc when you see the options. select cd dvd rom drive then press enter then run diags custom test for hdd.
Dec 08, 2009 | Dell Latitude D505 Notebook
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Installing win xp
Check in Bios whether your sata hdd is detected or not.if yes select the first boot driver to cd/dvd rom and second boot drive to sata hdd..
Jul 22, 2008 | Intel Motherboard
'Enter' button not working with DVD's
Hi - had the same thing. Hardware reset fixed the problem. Hold the power button for more than 10 seconds, and everything goes back to normal. And no, it's not in the manuals or on the toshiba web site.
Jan 02, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
