Question about Sony Cyber-shot DSC-N1 Digital Camera
Lens i dropped my camera accidentally.and when i turn it on,camera and video mode,it says,access.the lens goes in and out for 4x.after that,it appears in the screen,turn the power off and on again.
  • Anonymous Mar 07, 2008
    i dropped my sony cybershot DSC-N1 digital camera.it has a damage.lens dented.when i turn it on camera on and video mode the screen appears,access and the lens goes in and out for 4x.and says turn the power off and on again.
    Scholar:
  • 51 Answers
I can only suggest that you bang it around more, against your palm or other surface like hot pad, mouse pad, etc. that has some give and see if that undoes the damage (if it is a dis-connection issue). You didn't mention physically damaging it (as in dented) so soft blows and retrying the camera after each attempt may result in it working again. Try blows from different angles and speciffically from the opposite direction of the drop, if you know how it hit (a mark?).
It does sound like it is "hunting" for a sensor signal that it is not getting.
Posted on Mar 07, 2008
  • 23 Answers
I dont suggest to experiment with the dented lens as there are some plastic gears inside the lens unit, those can be break and if those gears will broken, it will be very difficult to re-find them.
So look for a authorised service center and get the camera repaired. If thay say for replacing the lens unit. You may search for an professional to get the camera repaired.
Regard's
Manoj Goyal, INDIA
+91-9214988557
Posted on Mar 08, 2008
Well actually my camera is a cybershot dsc-w100 and when i push the on button it says access but after that it goes to a mode where it says turn the power on and off again and i turn it off but still does...
Lens errors (access errors on Sony's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 01, 2011 | Sony Cyber-Shot DSC-W1 Digital Camera
When i turn on my camera it turns on then goes to a black screen and says lens error 0x0311. It was never dropped or anything its only a few months old it just started doing this one day.
There's a really good blog about fixing lens errors, and you can find it here. You don't have to have dropped it to cause this problem, it can be sand or grit in the mechanism, or it was accidentally turned on at a time when the lens could not come out.
Jan 20, 2011 | Cameras
Lens Stuck
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Mar 17, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
My optio was dropped with the lens going down first. now my camera makes noises & the screen is black. how do i go about fixing it?
looks like the gears or retracting mechanics are damaged.
its problably not worth to take it in, to get it fixed (depends on the camera). but most likely sound like the gears are busted.
you be paying for repairs that costing waaay more than the camera.
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Casio Exilim EX1050 10.1 Megapixels
Remove the screws/case and with power on, slightly push the lens back
make sure you disable the play mode so it not turn on by itself if you accident touch the play mode
hope this help
Nov 20, 2007 | Casio Exilim EX-S500 Digital Camera
Can't take new pictures!
 Delete some images then try
Still in trouble?
Come back
Oct 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
61 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
