Question about Belkin (F5D7231-4) Wireless Router
Belkin router I have a belkin router # F5D72314. I had a pc directly connected to it and wireless laptop.For almost a year there was no problem,then one day both were not connecting.I have cable modem going right to pc now,only way to get online.I called cable company and they said they couldnt detect router when I had it connected and turned on.Dont know why it suddenly stoppped working...any help to this?
I had the same problem recently. After *much* frustration, here's what worked for me:
1. Unplug power to router for at least 10 seconds.
2. Connected the modem to the router, router ethernet connected to the computer (not wireless yet).
3. Typed the IP address of the router into an internet explorer window. The default is 192.168.2.1. When the page came up, it said "No connection" in big red letters in the top right corner. The goal here is to get that to change to "Connected" in green lettering...
4. Went to the "MAC Address" topic from the left hand column (it may ask for your router's password to do this -- even though I had set a password previously, it apparently lost it's memory and was back to the factory default setting of blank password).
5. Clicked "Clone" and then "Apply settings". Nothing obvious happened right away, but I think this is what fixed it for me...
6. Clicked on another heading from the left column of choices (can't remember which one). At this point, I got the green "Connected" letters in the top right corner! Success!
7. I'm having trouble re-enabling some of the security settings I had in place before (such as changing my router IP and local domain name) but for now I'm just happy to be able to connect.
Hope this helps you!
Posted on Mar 21, 2008
I have a Belkin wireless G router- 2.4Ghz-802.11g I have had for years. A few days ago it stopped connecting to the internet. I can connect my modem directly to my laptop and get on the internet so...
Start by checking for "link" between the modem and wireless router. This is usually a tiny light built into the network port itself on each piece of network equipment. It should be solidly on if the link is good. If it isn't on, check that you have the network cables plugged in good and that the cables or connectors are not broken or damaged. If you have another network cable, try it instead of the one you were using.
If these steps don't help, you can try fully resetting your wireless router to factory defaults, then reconfiguring it again. Consult the manual for your brand and model of wireless router for this. It may also have additional troubleshooting steps.
There is a chance your wireless router has simply gone bad. I've seen new Belkin wireless routers for as little as $29, so you may want to go that route, rather than spending too much time trying to troubleshoot the one you have.
May 19, 2017 | Belkin Pre-N (F5D8230-4) (DBF5D82304)...
Wireless Belkin N300 will not stay connected to my HP Pavilion
It might not work Because your laptop should XP service pack 2 Or above
You can try upgrading your operating system before throwing your router out of the door
Jun 07, 2010 | Belkin Wireless Surf Router (F7D2301)
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin router gets me kicked off internet after 2-4 days.
It's probably temporary interference between the router and your computer.
1. Regrigerator, metal filecabinet, too many walls in between, etc.
2. Also, the router is using the same frequency (2.4GHz) as:
Microwave oven, cordless phone (not cell phone), Bluetooth headset
3. Move the router if you can to a higher location, and change the direction of the antennas (point the antennas in-line with the direction of the laptop).
4. If you obtain a different router, get one that uses "N" wireless, even tho your laptop uses "G", the "N" router can get around interference.
You do not have to change your "G" laptop to "N".
Sep 28, 2009 | Belkin (F5D8231-4) Wireless Router...
Adding laptop to home system through Belkin59G .
Good Day!
I believe you are trying to connect wirelessly using your laptop to your wireless router(Belkin 59G). Try to hook it up first on your computer and check if you can go online.
If yes, then that's the time you go to the router's set up page and check the wireless security of the router so that you can connect wirelessly.
If not, then you have to reconfigure the router and the modem. If your internet service provider is cable you can just turn off the router then the modem and waitfor 5 seconds. Turn on the modem, wait for the lights to turn on then the router. After that, check if the computer will be able to go online when connected directly to the router.
Feb 10, 2009 | Acer Computers & Internet
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7231-4) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
