CARRIER HEATER FAN WONT TURN OFF. PLEASE HELP
I just bought a house 2 years ago. Yesterday the fan just stayed on even with the heater off. We woke up this morning, to 56 degrees in the house. The fan wont shut off and when i turn the heat up it stays cold. Please help!!! I hear about trippin a breaker, where do i find that? What do i do??
  • rdmont81 Mar 06, 2008
    HELP
  • kdb4004 Apr 16, 2008
    having the same problem - carrier heater/AC unit fan won't turn off even after removing thermostat from the wall and then it immediately comes back on after power cycling the main power.
    Master:
  • 518 Answers
Need more information.... Is this a whole house unit, a window unit or what? Model #?
The breaker would be in your basement or wherever your breaker box is. If it's a 220 unit, one side could be kicked if whoever hooked it up used 2 seperate breakers (very unusual but it's been done).
Geno
Posted on Mar 06, 2008
My 1998 malibu runs hot when not moving, and now the heater wont work
Does the engines electric cooling fan turn on when it gets hot? Does it cool off if you turn the AC on?
Feb 24, 2012 | 1999 Chevrolet Malibu
How come heater fan wont blow
there are a few things that will cause this problem.
1. it could be the heater fan fuse
2. could be the heater fan motor itself
3, a bad switch or relay
check the fuse and then check for voltage at the heater motor itself, if you have voltage at the heater motor,, give the heater motor box a love tap with your hand and see if it starts to turn, if it does not turn or even if it does ( after tapping it ) - it is time to replace the heater motor.
c...
Jan 04, 2011 | 2000 Jeep Grand Cherokee
Flame won't stay lit
bobdukw,
This is a classic reddy heater problem. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 22, 2010 | Reddy RLP55V Utility Heater
Hi, I have a Brivis Buffalo. The heater will not run when the fan is set to auto even though the pilot light is on, and the wall controller shows heat on. When I set the fan to on, it just blows cold air....
My buffalo heater has just started doing the same thing about two hours ago, so will watch for any answers you get. My heater is over ten years old, maybe the heating element has "died"?
PLEASE can someone out there help us????????
Aug 02, 2010 | Heating & Cooling
Fan stuck on HIGH, cant turn it off
there is a mosfet power transistor that drives the fan.it is probably shorted,applying full power to the fan at all times,even if the climate control is off
Jul 25, 2010 | 2005 Nissan Altima
My heater stoped working. The houst has been sitting for 2 years and when I used the AC, I had to put a start cap on it for it to work. Now that its winter, the heater will not work. When I turn it on the...
did the start cap fail again didnt say if condenser fan was running if fan not running compressor will over heat and turn off or if coils of condenser are dirty wont let air pass thru
Oct 24, 2009 | Amana Heating & Cooling
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Heating & Cooling Logo
304 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
