Question about Samsung PCL545R 54" Rear Projection Television
Samsung sp42w5hfx rear projection tv
Can anyone tell me what part i need to replace when my tv comes on all the colors are out of alinement and the alinement tool in the menu cant fix it any ideas on this thanks in advance
  • Anonymous Feb 01, 2009
    Well all the colors are out of sync.. Don't know what to do, need to sort it or sell it !! Rather sort it or know how to..
    Not sure weather there is a bulb that needs changing or weather there is something else that needs sorting..
  • 579 Answers
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Posted on Mar 06, 2008
Color is gone
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Weird colors
need to replace the control board  they are notorious for frying up at the first sign of a power surge
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
SAMSUNG REAR PROJECTION TV SP42W5HFX - WON'T TURN ON
common problem with these sets is the convergance ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
however with out troubleshooting it it's hard to tell you might want to contact pts see how much to fix the board.
http://www.ptscorp.com/
Dec 14, 2007 | Televison & Video
Real projection tv model# pt-53wx42f
you need to replace (2) STK392-110s some are 120s 150s up grade to 180s.Also after you replace them you will have to do complete alinement of convergence in order to do this you must have service codes.
Dec 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Bulbs blown in samsung sp42w5hfx
Its hard to tell without actually knowing where the smoke came from. I doubt that any of the CRT's (bulbs as you say) caused the issue.
Nov 27, 2007 | Samsung HCM422W 42" Rear Projection...
Convergence problem with samsung sp42w5hfx
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Nov 04, 2007 | Televison & Video
Samsung rear projection sp42w5hfx convergence problem
Compare IC connections with meter = check solder joints to
see if some are touching one another. Tell me exactly what
brand & part number was installed...........T.
PS. The red,green,blue plugs may be mixed up because the green should stay and red & blue move !
Nov 03, 2007 | JVC AV-48WP74 48" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
361 people viewed this question
Jerry Greenberg
Jerry Greenberg
