Question about Kitchen Ranges
I am trying to find a glass inner door for a smeg multi pyro model SE2010MFX
    Master:
  • 518 Answers
Have you tried this site ? It's in the uk and I can't tell where you are.
Geno
Posted on Mar 06, 2008
Hi - I have tried to clean the internal glass panel of our Smeg cooker using an oven cleaner.
The brown stains are on the inner surfaces of the "sealed" glass panel.
Jan 08, 2018 | Smeg Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Loose door handle on SMEG SCA706X Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You may need to rotate the handle on some models.
Dec 05, 2013 | Microwave Ovens
SMEG F170-6 Inner Door Glass
no this glass is heat toughend throug out
Feb 17, 2010 | Kitchen Ranges
Fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Re Smeg 60cm electric oven model SA370 EB/1. I need new door glass and rubber seal for glass door.
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Jun 23, 2008 | Smeg Kitchen Ranges
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
