Question about Philips 20PT5441 TV
Philips no horizontal drive
My philips model # 20pt3732 not starting up no horizontal drive coming from tda 8841.
  • 44 Answers
Mike, First check out the voltages in the power supply start up circuits. You will need a schematic. good luck.
Posted on Mar 08, 2008
Hi! i have hitach CRT tv has a problem of switching. the power supply is okay but there is no horizontal signal.I have changed the video amp TDA 8362 but still the same problem.
You need to check if you have horizontal drive to the base of the horizontal out transistor. With a scope check the primary and secondary of the horizontal drive transformer to find out where you are losing the drive.
Feb 01, 2015 | Televison & Video
IN LG TELIVISION USING TDA 9370PS N3 1774 THE VOLTAGE AT THE COLLECTOR OF H DRIVER TRANSISTER BECOME 0
Disconnect the base of horizontal drive transistor, and now check it collector voltage. If it is found OK; [almost equal to its iput voltage]; check the voltage that comes to its base, from the IC pin. It should be below 0.1 to 0.25V. If found higher than this, the IC is faulty. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Daewoo Televison & Video
Keeps shutting off shortly after it comes on
This may be needing a horizontal drive kit. Unplug the CRT socket, to see if the TV will stay on. Also, look for discolored surface mount parts in the horizontal drive section that may be causing the problem.
Jul 03, 2010 | Philips 27PT543S 27" TV
I have a polytron tv model 21pp123. No horizontal oscillation
I have a polytron tv model 21pp123 ...whenever I turn on the power its turning off or standby.can anyone help me bout this trouble?
Jun 10, 2009 | Philips Televison & Video
How to set smart sound on polaroid tv model # tda-03211c
As far as I am aware, only Philips Magnavox has this option.
I did some searching and have yet to find this option for your tv. I will do further searching and let you know if I find anything different.
May 30, 2009 | Polaroid Televison & Video
Regarding 29gx1891/56r Philips Colour TV,LED keeps on blinking.
The problem was detected as a case of unregulated Power Supply Output. A sort of Crowbar is set in operation if the Power Out is above tolerable limits, which cuts off the supply to the Horizontal and etc. IC TDA 8362. The diagnosis was a faulty PWM IC 3842.
Jan 27, 2009 | Televison & Video
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Ic
TDA 4841 IC IS USED FOR horizontal and vertical scaning IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Sep 18, 2007 | Philips Standard 104S 14" cRT Monitor
Philips 20PT5441 TV Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
