Hi, i am building a electric snare drum for a yamaha xtreme 3, and i need a wiring diagram so i can get 3 zones. thanks
To begin helping you, Please give More details .
More details means more possible solutions, Include the things you
have done, to Remedy the questions you are having.
Where do you need to connect the snare drum? ( what unit ? Model )
Do you have a Professional Mixer? ( Model ? )
Could it be connected to PC? ( Via what connections to do you intend
to use ? )
Here are the connectors :
• MIDI IN/OUT
• USB TO DEVICE/TO HOST
• OUTPUT L/MONO, R (standard phone jack)
• DIGITAL OUT (EIAJ CP1201, IEC60958, S/P DIF)
• INDIVIDUAL OUTPUT 1 - 6 (standard phone jack)
• Trigger Input jacks 1 - 9, 12 - 15 (Standard stereo phone jack, L: Trigger Signal, R: Rim Switch)
• Trigger Input jacks 10 and 11 (Standard stereo phone jack, L: Trigger Signal, R: Trigger Signal)
• AUX IN/SAMPLING IN (Standard stereo phone jack)
• PHONES (Standard stereo phone jack)
• HI-HAT CONTROL (Standard stereo phone jack)
• DC IN 16V
if it pertains to the input wirings, still looking
thanks in advance for choosing Fixya for assistance!
here is a sample of drum trigger
you can connect it
You need a connection to a PC like these ( USB )
Of course , you need to install the Software , that comes with the unit
A sample Audio Connections
Trigger Input
hope these helps
Usually the Analog Audio Connector comes with the unit like these
it is available @
Stereo Right-Angle 1/4" Male Phone to Straight 1/4" Male Phone TRS Cable - 15'
B&H # HOSPMSPMRA15
Mfr # CSS-115R
http://www.bhphotovideo.com/c/buy/Stereo...
the internal connection
you can try one like these
here is a guide for the transistor
Resistors Color Coding
100K = Brown, Black, Yellow, Gold
1M = Brown, Black , Green, Gold
Guide for the Diode
I always buy Yamaha or Casio when it comes to electronic keyboards for kids. I think their products are well made but also are more affordable than some of the more professionally aimed products.
HI,
I AM USING A YAMAHA DTXTREME SOUND MODULE, AND CURRENTLY USING THE STANDARD RUBBER PADS THAT CAME WITH THE KIT.
I AM BUILDING A KIT THAT RESEMBLES AN ACOUSTIC DRUM KIT BUT INSTEAD OF STANDARD DRUM HEADS USING MESH HEADS AND PIEZO SENSORS TO TRIGGER THE SOUNDS FROM THE SOUND MODULE.
FROM THE SNARE DRUM I WANT IT TO FUNCTION THE SAME AS THE STANDARD YAMAHA PAD THAT I'M USING WITH THREE ZONES (CENTRE SNARE SOUND, RIM SHOT AND CROSS STICK) - WITH THE CURRENT RESEARCH I HAVE DONE, I THINK I MAY NEED TO WIRE IN A KEITH RAPER CIRCUIT (KRC), HOWEVER, I NEED A WIRING DIAGRAM WHICH SHOWS EXACTLY HOW TO ACHIEVE THE THREE SEPARATE ZONES USING ONE STEREO CABLE JACK.
THANKS -
