Question about Epson Stylus C60 InkJet Printer
My troublesome printer
I have a second hand epson stylus c60 printer, both red and green lights are on and my computer thinks it prints but it wont, i put new ink in and plenty of paper
  • 3 more comments
  • juneva Mar 06, 2008
    thank you lenny will give it about 15 minutes and i will try and print something
  • juneva Mar 08, 2008
    thanks how do i clean the cartridge contacts. since i removed selophane the red light has gone off and the paper went through but nothing was printed on it
  • juneva Apr 11, 2008
    THANKS EVERYONE WHO TRIED TO HELP WITH MY EPSON C 60 BUT IT WAS PAST FIXING SO I BINNED IT I NOW HAVE A BRAND NEW EPSON STYLUS CX4300/CX5500/DX4400 THREE IN ONE WHICH IS PURRFECT
    THANKS AGAIN JUNEVA
  • Anonymous Jul 23, 2008
    ink full ,paper in holder, pc tells printerto work head tracks across paper
    but nothing prints
  • sasivn May 11, 2010
    epson stylus cx4300 black cartridge not detecting how to solvec
Did you refill this ink cartridge? If the ink is low or out your printer will not print until the cartridge is reset. If you refill it yourself see http://www.ssclg.com/epsone.shtml. This is free software that will allow you to reset the ink levels. Then the red light will go out and poof you can print.
Posted on Apr 11, 2008
  • 133 Answers
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Posted on Mar 06, 2008
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
I have a blinking red and green light on my c60 epson printer that stays blinking. It wont print. What can I do?
you need to reset wast pad counter by using adjustment program. you can download a program "SSC service uitilities"
Dec 27, 2009 | Epson Stylus C60 InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
Epsom stylus c60
For the record, problem solved!
Mar 05, 2008 | Epson Stylus C60 InkJet Printer
Epson stylus c60
hmmm..is the cable from the printer to computer happy? unplug it, and see if it shows on the computer screen, when you plug it back in.
Its not working
Did you get a disc with it?
Have you installed the drivers?
If you didn't get a disc, go to the manufacturer's website and dowload the drivers, then try it again.
Mar 04, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer still not printing
what is the connection? USB or parallel ? Try1. Disconnect the printer. Unistall the software and driver. Restart the computer. Now re installed and follow precisely the commands. Come off line Disable A/V software Do not connect printer untill prompted. Try2 Go to printers and faxes Click on install printer When asked CD or select from List - take select ftom list. Select the Make. Select the model. Make it the default printer. Try 3. Go to www.fixyourownprinter.com
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
MY Epson Stylus C60 wont print
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
312 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
