Question about D-Link NetDefend DFL-200 Firewall
I need configuration aid for the DFL-210
Please, kindly assist me, i am trying to use the DFL-210 to replace the Linksys Firewall that i've been using to connect my office through a global ip address to the internet backbone. How do i integrate the DFL-210 to my network to accept a public ip address and issue out private ips to the several workstations on my network through the DHCP features and at the same time give sufficient firewal . The system of DFL-210 seem to be a bit different.
Please, help me out. I have been able to access it and configured it but it did not allow me to connect to the internet.
  • Anonymous Apr 15, 2008
    ples halp
  • Anonymous Jun 24, 2008
    Got the same problem. DFL-210 configured exactly as manual says and full access from LAN with no acces to PPoE connection to internet.
I had the same problem. I googled "DFL-210 Configuration" and find this link http://www.mydigitallife.us/2006/09/dfl210_quick_co.html. I follow those steps, and achieve to connect.
Posted on Aug 09, 2008
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
Posted on Apr 01, 2008
How i can reset factory my D-link firewall DFL-210
The easiest way to reset the firewall is hardware reset button. You can follow the following steps to reset the D-Link Firewall DFL-210
Hardware Reset button
Step 1 Make sure the unit is powered off.
Step 2 Press and hold the reset button locatedon the back of the firewall. While continuing to hold the resetbutton, power on the firewall.
Step 3 Continue to hold the reset button for 30seconds after the unit is powered on.
Step 4 Release the reset button and thefirewall will be at factory default settings.
Note: Only when the System light comes on solid will yourfirewall is ready for configuration.
For further information about reset through console connection and web configuration please refer here
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 08, 2011 | D-Link Netdefend DFL-210 (DFL210)...
How to block website on DFL-210
See below link may be helpful to solve your problem. Link.......
http://www.alris.com.hk/dbimages/document/141%5Chow_to_configure_http_alg_for_web_url_filter.pdf
Thanks
Aug 15, 2009 | D-Link Netdefend DFL-210 (DFL210)...
Unable to map server to storage media over the internet for back
Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
Check your configuration level and access policy.
If its a public server you have to place it in DMZ.
Check IP settings of the server. U may require a VPN tunnel
Rate if this is helpful
Thanks
Good Luck
Jun 01, 2009 | D-Link NetDefend DFL-200 Firewall
I need to reset the password
reset the router to default settings by pressing on the reset button for ten seconds. (usually located at the back of the unit)
May 12, 2009 | D-Link DFL 500 (DFL-500) Firewall
DFL-260 Fierwall setting for Static IP
All of these info below are available in the owner manual that you can download here :
D-LINJK DFL-260 Firewall
You can either do it true command line or with the web interface.
Apr 09, 2009 | D-Link NetDefend DFL-200 Firewall
Firewall is blocking incoming emails
Do you have an email server in place? If so, you need to setup port 25 for inbound access to the IP address of the email server. I would suggest that you don't allow all as that will open up everything and kind of negates the reason to have a firewall. Some ISPs block port 25 though and use port 587.
If you don't have an email server then the problem might be with your email client configuration.
Apr 01, 2009 | D-Link NetDefend DFL-700 Firewall
I want to set factury default to my fair wall dlink dfl 210
With the unit on, locate the small reset switch on the back of the router. Insert the end of a paperclip into the reset switch and hold for 10 seconds. The router will restart itself and the WLAN light will stop blinking.  The router is now reset to factory defaults.
Remember The factory defaults username is admin, and there is no password.
Feb 09, 2009 | D-Link Netdefend DFL-210 (DFL210)...
DFL-210, follow example to block web site
i have the same problem....try this
In order to enable port forwarding you need to create two rules on the DFL-210. The first rule is for service to Static Address Translation (SAT) and the second rule is for Network Address Translation (NAT) to Static Address Translation.
The first rule is created using the following steps:
  • Under Rules/IP Rules/wan_to_lan add a new rule
  • Under the general tabName = enter desired nameAction = SAT
    • Service = Select the desired service
    • Schedule = Select the desired schedule or None
    • Source interface = any
    • Source Network = all-nets (you specify a specific inbound address or range)
    • Destination Interface = core
    • Destination Network = wan_ip3. Under SAT tab
  • Under the SAT tab
    • check destination IP address
    • New IP Address = the address you want to forward to
    • New Port = the port you want to forward to
    • Create the rule by clicking OK.
The second rule is created using the following steps:
  • Under the general tabName = enter desired nameAction = Allow
Activate the configuration by using the Configuration/Save and Activate menu item.
posted.
Jan 06, 2009 | D-Link Netdefend DFL-210 (DFL210)...
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
Jun 20, 2007 | D-Link NetDefend DFL-200 Firewall
Open Questions:
D-Link NetDefend DFL-200 Firewall Logo
1,556 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
